3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Firecracker
Simple Firecracker
This is a simple / cheap firecracker you can make with four items and 5 minutes of your time.
First of all, I want to remind you that fireworks are dangerous .. even the cheap ones. I am not responsible for your actions.
With that said, let's get started.
Step 1What you need:
What you need:
- Tape ( any kind ... duct tape, masking tape .. etc ... but scotch tape worked the best for me)
- Two nickels
- Roll of caps ( caps that you put in cap guns)
*Note: I got these caps at walmart and on each roll is 5 separate strips which is all you need for one product.
48 comments
1-40 of 48next »
Jan 4, 2012. 2:14 AMwindstalker1992 says:
scotchtape is simply a strip of plastic with glue on it and ducttape is woven so where scotchtape suddely breaks with that nice hard sound the fibers in the ducttape restraint the energy and break only slightly
Apr 20, 2009. 7:52 AMBstnRedSox3312 says:
i through TNT in a fire once .... my friend died
Nov 15, 2010. 1:37 PMyeolddingdong says:
first of all is that true ? and if not knock it ,off death is not funny
Nov 15, 2009. 10:33 AMBOOM5601 says:
You need a blasting cap to ignite trinitrotoluene.
Nov 10, 2009. 8:28 PMScar16 says:
yeh well mine dide to so shut up
Sep 4, 2009. 8:55 PMjordanw343 says:
Yeah right BstnRed Sox 3312
Jul 14, 2009. 10:49 AMilpug says:
its hard to light tnt with fire, and even when lit, it doesnt explode much morethan an equal wirhgt of gunpowder. what really makes tnt blow is the explosive force of a blasting cap that compresses the molecules and make them react violently, ie, explode. if your frind died, that sucks, but give proof or i wont believe u. also, how hte hell did u get your mitts on TNT?
May 11, 2009. 7:11 PMmatt7 says:
yay right
Jan 2, 2010. 1:03 AMrussian5 says:
Nice ible. I've got a suggestion for the folks on here. Take a buttload of sparklers and empty them into a film canister. pack it in really tight. Make a hole in the cap and use whatever you want for a fuse. I got a white flame that went up at least 10 feet. There wasn't even a trace of the canister left, it was obliterated. And it burned the sidewalk. Oh yeah, wear sunglasses.
Jan 4, 2010. 2:33 PMzack247 says:
awesome. im gonna try putting that into a toy hummer, and seeing how much damage that causes (i might try 2, not sure)
Jan 22, 2010. 3:21 PMrussian5 says:
Good idea. I'm going to try putting one of 'em into something metal and see what happens.
Jan 22, 2010. 4:11 PMzack247 says:
awesome. i cant wait to see the results
May 3, 2008. 3:23 PMYummyPancakes says:
hehe...
hahaha...
MWAHAHAHAHAHA!!!!!!!
Sorry... bit of a pyromaniac.
Jul 14, 2009. 10:51 AMilpug says:
i can relate to that...
Jan 4, 2010. 2:34 PMzack247 says:
yes. my favourite part is the destruction
Jul 22, 2009. 11:37 AMdasandmankilla says:
holy crap this rocks works also with long small rocks!!! it woke my baby up he was inside and I was out at the end of the culdasack
Mar 25, 2009. 5:55 PMclayball97 says:
what happens if you set one on fire like a real firecrackers
Jun 18, 2009. 10:51 AMmacgyver603 says:
You could stick a sparkler in the end and light that as a fuse.
Jun 18, 2009. 3:04 PMclayball97 says:
good idea i could use that soon with 4th of July coming up
Jun 9, 2009. 1:04 PMcodongolev says:
I've seen it done where the caps are wrapped around a sparkler and taped in place. that way there's a fuse.
May 23, 2009. 9:52 AMJupitane says:
Is this a firecracker???
its easier to just take all five and drop a brick on them or put a brick on the and jump ont it
Jun 12, 2008. 1:56 PMwiiman07 says:
it was three am at scout camp i couldn't fall asleep so i made one of these and chucked it into the fire it was so loud that everyone at my camp site woke up GREAT INSTRUCTABLE!!!!!!!
Apr 18, 2009. 9:30 PMgoeon says:
camp gardener?
Dec 3, 2008. 4:31 PMmazeka.14 says:
sounds lik you enjoy camp:D
miss spelled.
Jul 6, 2008. 2:06 AMAnarchistAsian says:
it's probably louder with scotch tape, because it tears faster and holds more pressure than duct tape =>
May 28, 2008. 10:48 PMPyro Master says:
Were do i get caps
Jun 27, 2008. 7:34 PMskimboarder33 says:
1$ store
Jun 12, 2008. 12:37 AMEviLNinJa says:
WTF PYRO MASTER DOESNT KNOW WHERE TO GET CAPS?????????
Mar 19, 2009. 4:15 PMrownhunt says:
dont dis him not everyone knows were to get caps
Oct 14, 2008. 3:52 PMslipknotFTW says:
lol i know. but i dont know where to get those caps either. well i didnt until now
Mar 19, 2009. 6:52 AMmechamaggot says:
could i launch this out of a potatoe gun or would it go of in the barrel?
Jan 4, 2010. 2:36 PMzack247 says:
you probably could if you put something behind it to absorb the shock
May 4, 2008. 11:13 PMgschoppe says:
the most economical way to do this effect is with two bolts and one extra long nut... you screw one bolt half way onto the nut, place a single, or stack of caps in the center of the nut, and screw the other bolt on over them tightly... that way you have bolt-cap-bolt, surrounded by the nut... when you throw it and it goes off, the gas has to escape through the threading, and it appears to vield a more satisfactory "pop" than my earlier experiments with rocks... btw its economical because its reusable, and only uses 1-4 caps
May 3, 2008. 5:08 PMPKM says:
Nice variant on one of my childhood favourites. The recipe I used:
- fold caps in half down the middle
- assuming you have 100 caps per roll, count out twenty and fold the strip over on itself so you have five rows of twenty next to each other
- press tightly together and wrap tightly with packing tape, leaving the paper end of the cap roll sticking out as a fuse. I know masking tape doesn't work, we never tried duct but packing tape is the undisputed king.
Tape to a wall or something vertical in a non-flammable area (possible danger of burning fragments, keep away from dry vegetation etc.) with the fuse sticking out downwards. Light fuse and get at least a couple of metres away. This will really, really make your ears ring closer than that.
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fade400
