3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Firework Detonator
This instructable will show you how to make a cheep detonator that works realy well. It is made to be used with my ignighters instructables.
Step 1Supplies and Tools
Supplies and Tools
  • last photo ←
Supplies:
+1 prodject box.
+2 switches, i used a toggle with a cover and a momentaraly push.
+1 9v battery terminal.
+1 9v battery.
+2 aligator clips.
+insulated wire.
Tools:
+wire stripers
+Drill
34 comments
Feb 6, 2012. 5:41 AMemadsiddiq says:
http://www.instructables.com/id/Make-a-bomb-no-potassium-nitrate-used/
OR
http://hacknmake.blogspot.com/
please read it and comment :)
p.s i am 13
Nov 9, 2011. 5:40 PMstevepal says:
Hi, Please Could You Tell Me Do You Know The Crocodile Clips Where Do You Attach Them To And In What Way Round To They Go. Thank You
Stevepal
Sep 24, 2011. 1:19 PMTimmyMiller says:
where did u get the stuff?
Aug 20, 2011. 11:50 PMPyroWork says:
i made mine, it doesn't work.. i used a toggle switch that has only 2 connections.. is it because of the toggle switch or beacuse i connected it in the wrong connector?? pls reply. :D
Sep 22, 2011. 1:28 PMda_tech_man says:
you need a more powerful batt. with longer wires to the ignitor
Jan 21, 2011. 12:03 AMPyroWork says:
where will i hook my wires in the toggle switch???can u make a video testing this???
Nov 2, 2010. 12:55 AMfullysik says:
is there a specific wire i have to use or can i just use any wire
Jul 2, 2010. 8:39 PMaeronut01 says:
What kind of igniter did you use? The ones I use require 3 new 9 Volts wired in parallel to work, but yours only needs one!
Jun 29, 2010. 7:38 PMerie94550 says:
I made this and used your igniter and it didn't work.. SO i checked the voltage and its only putting out about 8.88 volts instead of 9v. Should that effect it??
May 2, 2010. 1:34 PMPatented says:
looks good but its the same as lighting up your fireworks with a lighter because your wire are way to short , you should make them longer so you could detonate your fireworks at distance
Mar 28, 2010. 12:40 PMXIIIDom says:
Looks pretty good - will it ignite steel wool?
Oct 5, 2009. 7:10 PMomfgitsjustinx3 says:
for the toggle swich which one do i put my 9 v connecter the ground power or acc
Aug 8, 2009. 1:08 AMbighead5454 says:
i could just imagine playing a prank with this yelling at the mailman FIRE IN THE HOLE then flip tthe switch or whatever and barely a poof of smoke comes from the mailbox
Jul 18, 2009. 5:29 PMmr_goodbytes says:
bro, you're thinking too big. u should use a smaller box caus you have very little wiring. check out mine, its basically the same as yours except in a nice, handheld package
http://www.instructables.com/id/Super-Cool-Electronic-Detonator/
Jul 2, 2009. 11:48 PMmage says:
would this work with model rocket ignitors?
Jun 13, 2009. 12:57 PMjason kb says:
this is kool
Jun 10, 2009. 7:27 PMstriker95 says:
what size project box is that . p.s. good instructible
Sep 22, 2008. 10:46 AMwazzup333 says:
I was just wondering if there was a certain shop you can buy the items for this intractable like radioshack by the way nice Instructable
Nov 1, 2008. 11:46 PMpyra_builder_1337 says:
ya probly radio shack or the source would have this possibly a hardware or automotive store as well
Dec 3, 2008. 8:58 PMamenchoid says:
On the toggle switch there are three connections one for power one for ground and one of ACC. Does it matter which ones I hook the wires to?
Aug 26, 2008. 8:03 PMCoodude26 says:
Nice does that switch light up when you use it?
Sep 3, 2008. 5:24 PMlunchboxslayer27 says:
yes it does, i used the same switch for a different project. its cool, but it kinda sucks up the battery......
Aug 5, 2008. 12:37 PMH0NDARACER12 says:
is it OK if I use positive on one wire and ground on another?
Jul 31, 2008. 6:04 AMMasteroffencing says:
with that size box u could add a bigger battery and then it would work better
Jun 18, 2008. 8:05 PMchi chi chippy says:
will it light a fire cracker the fuse? cuz that is wat im looking for something that will light visco. so if u have something tell me plz .
May 25, 2008. 7:24 AMGiller12 says:
It doesn't work
May 23, 2008. 12:30 PMacaz93 says:
it looks Neat , and kind of professionnal , i liked it ,
but just one thing my friend , isProject not Prodject
May 23, 2008. 2:41 PMPatrik says:
Just one thing?
cheep realy ignighters finnished prodject momentaraly aligator stripers pyrotechnicks prodect dont your
:-P
May 23, 2008. 3:17 PMacaz93 says:
Don't be too Rude.... justa kiddin' Xp
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Zdawg
