loading
Step 10: Mount and Enjoy
Finally all that is left to do is slide the shelf onto the fixings stand back, admire, and enjoy
Could this be done in dry wall to hold light wt decorative items. ?
<p>How thick was the wall to hold this? Did you drill into wood studs? Would expansion bolt work in studs?</p>
<p>Yes it's for concrete walls. </p><p>You could put more weight on it if you put the threaded rod all of the way through the board, and counterbore the front of the bore like you did the back of it and put a washer and nut on the front and tighten it to the wall. Then brad nail an trim edge to the front of the board. But the edge of the back of the board would have to be true 90 degrees to the top of the shelf or it could tilt up or down when tightened.</p><p>If it tilts up you could call it a preload and put even more weight on it. Ha ha.</p>
Is this for concrete walls? If not what is the hammer drill for?
Good work, I suggest to use TMT bar which can be hammered in both parts using drill bit slightly smaller in diameter than bar.
leonroode... i salute your sharing of the wonderful floating shelf.....cheers!
Thanks - this is a great instructable. I used it to make a spice shelf for my kitchen, using recovered construction scaffolding wood!
So, How much weight do you thing those thread bars can take before they fail?
@reptedjess the weight factor would realle depend on what thickness thread bar you use. The two i have made have both been with 6mm bar because they are intended for light stuff but if load factors were higher i would use a thicker thread bar. but also remember that the depth of the shelf will play a huge factor in the whole equation. ie the deaper the shelf the more leverage on the fixings
wow well done!!! :) <br><br>very cool
Thank you. I will be making this today.
Love it and good execution
Thank you
Very pretty!
Thank you
About This Instructable
248,982views
350favorites
License:
More by leonroode:Leather keychain  Simple Floating Shelf
Add instructable to:
