3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple High Voltage Flyback inverter [without feedback coil]
Step 3The secondary coil
The secondary coil
Finding the secondary coil isn't so hard. (wire up a test circuit like on the picture)
- Take a 5-25V power supply (safe voltage) or a 9V battery (the polarity doesn't really matter).
- Connect the + from the V-meter to the positive HV output (thick wire at the top).
- Connect the - from the V-meter to the negative side of your power supply.
- Touch every pin on the flyback transformer.
- when you found a signal, equal to the voltage of your supply, that's the 0V pin from your secondary coil!
3 comments
Oct 27, 2011. 6:56 AMgeckomage says:
actually i did a different set-up. i hooked the positive end of the volt meter to the hv. out. the low end of the volt meter to the low end of the power supply, and then used the positive end of the power supply to test around and find it. i found this on another page and it was described there to usually lower the voltage. but generally the secondary coil has a huge amount of resistance (hence why you must use a voltage and power to find it) because otherwise you would need a fancy volt meter to find it. but this resistance goes down when voltage is increased, and the frequency is increased. and most driver circuits run these at 15-25khz ish (correct me if im wrong) and since both the voltage and frequency is increased it lowers the resistance of the secondary coil while in operation. :)
Oct 26, 2011. 11:45 AMgeckomage says:
I do not know if anyone had anything similar occur but with this same setup i applied 24 volts to it (as i found on a different instructable) and only got about 12 volts on the HV 0v pin. but none of the other pins showed any voltage. hope this helps someone!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:Electorials(My YouTube channel)
I'm really fascinated by science! From when I was young I've been curious about how stuff works and how I can create those things myself. Now I don't want to just learn things myself but I also want t...
more »
