3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple High Voltage Flyback inverter [without feedback coil]
Step 7Creating the circuit
I used a breadboard to place the components on, but it's really not required, it's just easy to work with if you have it.
Alligator clips can move around and make short circuits. That's why I like to use as less as possible.
You'll have to experiment with the polarity of the primary winding. Choose a random polarity and test the output voltage.
Now change the polarity, and test it again.
Choose the polarity which had the best result.
(you can find the steps for finding the polarity in step 8)
Make sure that you connect the Negative side of the HV coil to the Gate, else it won't work.
The negative side is the side that doesn't shock you.
The positive side is the one you don't want to touch, and that shows corona discharges.
13 comments
Oct 26, 2011. 11:44 AMgeckomage says:
I know this somewhat defeats the purpose of your instructable (which i will try tomorrow and see how well it works :) then post results) but do you know of any good way to detect a feedback coil in a flyback? im thinking of using a 20 volt 2 amp freq generator to make a square wave at around 20 khz and using an osciloscope to find which set of pins gives me the right wave form for the feedback ( i did get some crazy waves comin off of the secondary, but no arcing :[ )
Oct 27, 2011. 9:15 AMgeckomage says:
haha no worries. we have a pretty heavy duty oscilloscope aside from the regular ones and have several special probes for it. from bumping up really small voltages to where you can clearly see the waves to taking up to 30 kv and bumping it back down to see the waves without frying the osciloscope ;) (had a bunch of sponsors donate generously to fund the program) got a full electronics lab, the full autodesk, mastercam, and multisim swuites on some powerful computers. a full wood/metal shop with lathes and mig and tig welding machines included. also a large 3 axis cnc mill, a smaller 4 axis one, a smaller 3 axis prototyping one and a cnc plasma cutter. :) ill only have acess to it till the end of next semester though, so if you have anything you'd like me to try to build for a project that you'd like to test let me know ;D we have a circuit board printer too but thats not quite working yet :( and thanks for your speedy replies and advice! :D
Mar 23, 2011. 8:42 PMnjkl44 says:
Hey thank you again i can finally play with high voltage EASILY!!! what is the voltage output on this thing (volts?)
Aug 6, 2011. 8:58 PMfiredude20123 says:
usually 100,000 volts is feasible not sure how easily tho
Aug 13, 2011. 1:19 AMspark light says:
100,000 volts is the opposite of feasible. especially for a flyback alone.
were you thinking of a tesla coil?
Aug 13, 2011. 9:46 PMWanderer.Anthony says:
Maybe not alone, but a voltage multiplier on the output side might work.
http://en.wikipedia.org/wiki/Voltage_multiplier
Aug 13, 2011. 6:53 PMfiredude20123 says:
actually it can, you just have to do it right, im not sure how but look it up online you'll see 100kv sparks
Aug 13, 2011. 7:12 PMspark light says:
at 100,000 volts, the flyback will internally arc, causing a meltdown. i'm 100% sure it's impossible because the ferrite core will be an instant path between the two ends of the coil. even under oil, it is highly likely that it will arc internally. the most i've ever seen is about 70 - 80kv. anyone who claims they've gotten to 100kv is most likely optimistically overestimating.
Mar 27, 2011. 8:14 AMNPD2705 says:
I only see the 15+, where's the cathode ????
Mar 27, 2011. 4:28 PMNPD2705 says:
the cathode of the battery, there should be a line that connect to the 15-
Mar 28, 2011. 5:40 AMNPD2705 says:
thks, a lot :D
Mar 27, 2011. 5:26 AMNPD2705 says:
hey can you tell me what the HV- is ? Is it the one with the sucken cup ?, and what's the negative side ? is it the plastic cover ? THKS
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:Electorials(My YouTube channel)
I'm really fascinated by science! From when I was young I've been curious about how stuff works and how I can create those things myself. Now I don't want to just learn things myself but I also want t...
more »
