3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple High Voltage Flyback inverter [without feedback coil]
Step 8Polarity of the primary coil
As said in step 5, it's not really easy to find the polarity of the primary coil, but this a way to do it:
- Choose a random polarity, and make the schematic from step 6.
- Make sure that the Negative side of the HV coil is connected to the MOSFET's Gate pin.
- Plug it in, and don't touch anything.
- There will be corona discharges (purple plasma around sharp edges of the wire, like in the picture) on the positive HV side, if you wired it up correctly.
- If there are no corona discharges, invert the polarity of the primary coil.
21 comments
Aug 24, 2011. 5:48 PMUmniscient says:
I don't understand what you mean by "the polarity of the primary coil".
Does it mean which side of the primary is connected to the resistor/12 volts and which side is connected to the Drain?
I've tried both directions, and seen no corona discharges at my HV +. The secondary measures at a few millivolts. In fact, I believe my circuit is inputting DC to the primary coil.
Or is my understanding incorrect?
Aug 25, 2011. 2:09 PMUmniscient says:
I did what you said, and it turns out that my MOSFET was broken.
Would this work well instead, or is the current rating too low?
http://www.radioshack.com/product/index.jsp?productId=2062618
Thanks for your help!
Aug 25, 2011. 4:40 PMUmniscient says:
I first measured the voltage over the primary coil: 12V
Then I measured it when the gate was disconnected: 12V
There was no drop to zero, so I figured there was something wrong with the MOSFET.
After I realized this, I plugged in another random MOSFET and tried it. No HV on the secondary, but a drop from 12 volts to 2 volts when disconnecting the gate. Does this mean the transistor is working? Or does it have to go to 0V?
Aug 26, 2011. 3:20 PMUmniscient says:
Yes, that was the result.
I went ahead and purchased the IRF510, and I'm going to try it soon. Just a question: is there a minimum voltage required to operate a MOSFET? That is, can I theoretically use any voltage under 12 and still get an output from the inverter circuit?
Aug 27, 2011. 9:07 AMUmniscient says:
All right.
Well, I read the IRF510 datasheets and connected it into my circuit accordingly.
Measurement on the primary: 12V. Disconnected the gate, still 12V.
Now, I'm not sure if the inverter is even outputting AC, because my multimeter shows 12V AUTO. When I manually switch settings to AC, I only get a few millivolts. Does this mean that the recorded 12V is in DC? It would explain the lack of output on my secondary coil.
Aug 27, 2011. 9:54 AMUmniscient says:
I don't get a small spark, but when I repeatedly connect and disconnect the 12V, there is an output of a few volts on the secondary.
Aug 27, 2011. 10:01 AMUmniscient says:
Also, I doubt the transformer itself is broken.
You see, I have a signal generator capable of outputting 5 volts. When I set it to 40 kHz and plug it into the primary, I get about 600 volts on the secondary, with lots of sparks and buzzing noises.
Aug 28, 2011. 1:29 PMUmniscient says:
"oh, and is there a way we could chat somewhere while you're working on your flyback"
Sure... do you have a Gmail account?
Sep 4, 2011. 12:05 PMUmniscient says:
Sorry for my delay!
Yes, it's okay. I have Hotmail as well.
Oct 8, 2011. 9:56 AMUmniscient says:
Hey, I managed to get it working using a slightly different arrangement with a 2n3055.
Aug 27, 2011. 9:55 AMUmniscient says:
Yes, I've tested the primary polarity each time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:Electorials(My YouTube channel)
I'm really fascinated by science! From when I was young I've been curious about how stuff works and how I can create those things myself. Now I don't want to just learn things myself but I also want t...
more »
