Introduction: Simple GPS Logger
Picture of Simple GPS Logger
Let's make a gps logger with an arduino mini pro!
I made this project so I could easily record my track when i'm trekking.
I wanted something simple and cheap.
You just have to turn it on and it will record your track as soon as the gps founded the satellites.
In this tutorial, we will see
  • How to wired everything
  • How to upload the code
  • How to display and convert tracks
Feel free to ask any questions, all the code/video/documentation are MIT/CC Attribution licence
As always I tried to put everything in a github repository so you can modify/reuse/correct/translate anything.
Before I start a small trick on Windows to download my projects without even opening a web browser
  • Press : Windows Key
  • Type: gps.madnerd.org
Step 1: Components
Picture of Components
Here is the components I used for this gps.
  • Gps module ublox Aircraft model mwc: 8€
  • Micro sd card 2go : 4€
  • Batteries holder 4AAA on/off : 1€
  • Arduino mini pro 3.3V : 1,50€
  • Passive buzzer 3v: 1€
  • Total : 15.50€
Before you read the other steps, watch this short video, where I show all the steps to make this gps
As for all my videos, editing was done on Blender
Step 2: Wiring
Picture of Wiring
Here is how to wired everything on an Arduino
  • You can use a sdcard module instead of an Micro SD card adapter.
  • Do not plug the GPS serial on the arduino serial or you won't be able to use serial to debug/upload code.
  • SD card works on 3V, use an arduino mini pro 3V
SD card Adapter
  • 1 --> X
  • 2 --> 12
  • 3 --> GND
  • 4 --> 13
  • 5 --> VCC
  • 6 --> GND
  • 7 --> 11
  • 8 --> 10 (Chip select)
GPS
  • RX --> 2
  • TX --> 3
Buzzer
  • + ---> 9
  • - ----> GND
Step 3: Upload Code
Picture of Upload Code
You will need an 3V FTDI cable to upload code on your Arduino
  • Copy the code / librairies into your arduino sketchbook (gps.madnerd.org)
  • Board: Arduino Mini Pro 3V
  • Processor : Atmega328 (3.3V, 8mhz)
At the beginning of the code
You can change the timezone:
const int timezone = 0;
You can also change how many times the gps saved the position
const int gps_interval = 15 * 1000;
Step 4: Read the GPS Track
The track is saved as a csv file, if you want to convert it or display it on a map, you will either need to use the website gpsies.com or the free software viking.
Gpsies.com
  • Go to http://gpsies.com
  • Click on Create a track
  • Import the csv file
  • Or click on convert to get a gpx track file
Viking
  • Add a map in layer
  • Use Open Street Map (Mapnick) or Bing Aerial
bwh13 (author)2016-11-07
Nice project.
Moving forward, consider placing your battery pack beneath your GPS module. The antenna works best with an unobstructed view of the sky
Anirudh Ralhan (author)2016-11-07
Nice!!!
About This Instructable
5,963views
130favorites
License:
More by madnerd:Lipo-battery Powered ArduinoSimple MIDI BuzzerMake NES Music with LMMS
Add instructable to:
