Simple K`nex MORTAR
1,455
Published
Introduction: Simple K`nex MORTAR
This is my first instructable so go easy on the comments, thank you.
This is my mortar it does not fire very far but it is pretty cool. This Mortar uses 89 pieces and is very simple to make.
note: I am not responsible for whatever you do with this Mortar.
Step 1: The Parts List
This is what you`ll need to make this.
Rods:
Green-4
White-11
Blue-14
Yellow-12
Gray-4
Red-1
Connectors:
Purple-22
Blue-2
White-3
Green-2
Red-4
Yellow-2
Grey-2
Orange-3
Tan-2
1 yellow or red gear
And you will need 2 rubber band/elastics
Step 2: The Stand
This is what will hold the barrel at an angle, Also whatwill keep it stable.
pic. #1:Build These two.
pic. #2:Connect like this.
Step 3: Barrel
This is the barrel of the mortar
Pic. #1:Make this.
Pic. #2:Also make this.
Pic. #3:Finished Barrel
Step 4: The Fireing Pin
This Will Luanch the Bullet.
Make this bye looking at the picture.
Step 5: Putting It All Together.
This is were you will assemble every thing you just made.
Pic. #1:This were the elastics from the fireing pin will attach to the barrel, put the green pegs over the elastics so the fireing pin will not fly out of the barrel when you fire.
Pic. #2:The stand connects to the barrel like this.
Step 6: The Amunition
This is the bullet that will be fired from the gun.
Simply look at it and build it.
Step 7: Loading and Fireing
To load this you push the fireing pin back so the red rod goes throught the snowflake and clip an orange connector at the end of the red rod for sort of like a trigger/safety.
To fire simply unclip the orange connector.
Have fun and feel free to modify.
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    11 Comments
    to make this actully work, put a blue ball, you know the one where 2 peices connect, a put a blue rod on the bottom. make sure when loading to put the rubberbands on the connecter thats atched to the rod.
    Don't build this instructable, it shoot 1 foot...... Literally.
    whatever you made has to be better than this one
    this is not a mortar for one you drop an explosive shell down the barrel and its on hindges for angleing your lauch 2*
    If you adjust the ratio of the rods on the support then it strengthens it and reduces rod-bend.
    this socks launches six inches
