Simple LM386 audio amplifier
video Simple LM386 audio amplifier
The song is:
Infected Mushroom
semi nice
FAQ:
Q: The sound sUxx0rz, fix it!
A: Can't, since there are barely any parts.
Q: How do I add volume control?
A: Either in series with the speaker (volume) or between pin 1 and pin 8 (gain)
Q: Why is there a 7805?
A: To conserve power, you can go without it if you feel like it.
74 comments
1-40 of 74next »
Nov 5, 2010. 4:08 PMJohnny Lavabo says:
I want to build this into something ( a music led box) i already made, but it has a 12 v power supply. Can i just add this to the same supply or do i need to do something else?
Dec 15, 2010. 11:11 PMDaHandy says:
Could you please post schematics for this? Thanks!
Mar 1, 2011. 2:49 AMcodestroy7 says:
To anyone out there :)
Some of my music has heavy bass, but the amplifier cannot output it properly due to lack of power. Is there a way in which I can "precharge" the amplifier so that it won't lack power when a heavy bass comes?
Mar 4, 2011. 3:19 AMcodestroy7 says:
Actually when i use DC adapters capable of delivering 5 volts at higher amperes, the bass is good, that's why i'am sure that its not my speaker. Since i want to create a pocket amplifier, adapters should not be considered as power source, so i want to know if i can create something like precharging the amplifier so that it will be ready for a bass comes.
Thank you for a reply i'll try putting a low-pass filter. i'll just post here what ever will happen to my amplifier :))
Oct 6, 2011. 10:55 AMlworm says:
Hey Kirbsome! I got a question. I'm some kind of new in that kind of projects ... So why do other users use Capacitors for their amps, what does that change?
Best Regards
Oct 10, 2011. 1:20 AMlworm says:
Hey Kirbsome!
Thank you very much - that helped alot, that was a great reply!
Have a nice day,
Lenwo
Oct 24, 2011. 10:58 PMmak24 says:
hey Kirbsome....
i tried the circuit on a breadboard first and although i was getting the output it was tooo noisy... i mean... i pulled out the jack from my ipod earphones and connected them to my droid.. and used the wires to emulate the circuit on a breadboard.. but on a breadboard the output was too noisy... the song itself was not identifie\able over the jittery noise after sometime.
Oct 24, 2011. 11:11 PMmak24 says:
@kirbsome..
how do you deal with the noise, i constructed the same on a breadboard and found too much noise
Aug 16, 2011. 1:31 PMmedwards2 says:
I just made my second one of these :)
Jul 9, 2011. 7:57 PMjgonzález19 says:
nice! (Y)
Mar 5, 2011. 8:42 PMcodestroy7 says:
to Kirbsome.
i placed a high-pass filter to remove some of the very low frequency bass, now it sounds good. the next i'll try is removing the filter and applying a dc-dc conversion i think it will work but i'll just try to be sure. :) i'll just inform you what will happen next :)
btw. why did you suggested putting a low-pass filter? low-pass filter will remove high frequency audio right?
Sep 20, 2010. 9:07 PMroeggebear says:
ok i really want to make a amp but i can't find the amp chip in my broken sound system there is three chip that got same number as pins but it isn't a lm386 it is like a fm388 i think from top of my head im new to this stuff
Sep 21, 2010. 5:09 PMroeggebear says:
it is f4558
Feb 12, 2011. 11:36 PMpfred2 says:
4558s are just dual op amps. They can amplify audio but they are not specifically designed for it. I'm using a dual op amp in this circuit as a preamplifier:
http://img683.imageshack.us/img683/1641/p1010007ep.jpg
Hey Kirbsome my amp is made out of all scavenged parts too! It puts out about 15 watts.
Mar 4, 2011. 4:54 PMpfred2 says:
This is the page I got the schematic off of:
http://www.redcircuits.com/Page1.htm
Though I modified it somewhat because I didn't feel like using a high voltage op amp. So I put regulators on board it to run the preamp. I scored some vintage JRC OP amps off a board I salvaged and used one on it. They rock!
That project is only so so a really hot one is this:
http://www.gmarts.org/index.php?go=217
The schematic at the bottom of that page is the have all and end all! I took the one I made to a music store and let the guy there play with it some. After he got done all he could say was, how much do you want for it? I just smiled and said, not for sale. It is a worthwhile project to do.
I've my Eagle files for it but no way to host them. If you'd like I can try to attach them somehow here. A screenshot of the overdrive board:
Feb 24, 2011. 5:59 AMcodestroy7 says:
What should i do?
The sound is too noisy. The noise is even amplified when i hold the wires from the audio source.
Dec 26, 2010. 1:52 AMDaHandy says:
Thanks for the schematics but I can't figure out where does the A cords go from the transistors... Could you please explain that?
Dec 29, 2010. 4:26 AMDaHandy says:
Are those pontentiometers then? Why aren't they shown on the video?
Dec 27, 2010. 1:11 PMcimbru says:
(removed by author or community request)
Nov 16, 2010. 1:05 PMkidmundo says:
instead of using the lm386 tda can I use 2004 or 2005?
Oct 15, 2010. 1:48 PMnedim155 says:
add a cap batwen pin 1 and pin 8 (mine cap was 1000 micro farad) and it would be much louder
Sep 30, 2010. 7:29 PMcardboarddude says:
i omitted the 5v limiter so i connected the other side of the battery to where the limiter wouldve gone and it isn't working
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:Kirbsome!(Youtube)
Every single thing I make is from trash, I can't throw anything out! Well, most things are. Do you have any idea how hard it is to scavenge a 24.000 MHz crystal? Best 2 dollars I ever spent.
