3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Laptop Stand
Simple Laptop Stand
I always use my laptop on my lap, and it tends to get really hot. I looked online for some kind of stand, but they were all really expensive. I made my own out of a scrap of plywood and some rubber. Now the laptop sits nicely on my lap and still has airflow around it.
Step 1Gather Materials
Gather Materials
I used a piece of quarter inch underlayment plywood that I found in the garage. I then used a scrap of industrial grade rubber that was lying around.
14 comments
Dec 4, 2007. 11:54 AMpape21 says:
this is a similar to what i have just made for my laptop. it kept overheating when i had it on my lap and i didnt really have anywhere to store all my things (harddrive headphones, mouse etc). i made one out of wood with a 3/4 inch deep storage area inside and put a foam base on it. if anyone wants pics , reply and ill post them
Oct 17, 2011. 10:28 AMOSSMA says:
hi, im not sure if you'll get this but i am doing a business idea for my school and i was wondering if you could put an image on so i could put it on, your idea is really good, and was wondering if you could give us some tips thanks.
Mar 12, 2009. 5:36 PMlukkbox says:
despite the name 'laptop' ... laptops were never designed to be used on your lap bro they have air intakes UNDERNEATH and your lap/knee/nuts are blocking the only source of cool air IN this is the cause of your overheating OP' has made a fine example of a DIY riser nice one OP!
Feb 21, 2008. 6:54 PMgizmology says:
Yes, yes, let's see it!
Feb 18, 2008. 10:22 PMinertia18 says:
Please post some pics here. thanx
Feb 18, 2008. 8:49 AMbmciver says:
The possibilty of storage sounds nice. Let me see them pictures.
Mar 12, 2009. 5:38 PMlukkbox says:
i made one of these from a plastic breadboard wrapped in foil to keep microwaves off of my nuts works like a charm nice one OP
Sep 14, 2007. 12:26 AMbretthall says:
I've got a thing called the lapinator (which isn't DIY..) but is basically a foam pad with a semi-hard top to keep the laptop cooler. Well designed and inexpensive, I use it often.
May 10, 2006. 3:21 PMmomster451 says:
There are these squishy, cheap pillows from Walmart that you could glue to the back to make a more fitted surface for your lap.
May 3, 2006. 9:56 AMll.13 says:
(removed by author or community request)
May 2, 2006. 12:14 PMianturton says:
I've made a similar stand/board. I glued foam rubber to the underside and covered it in fabric to make it more comftable on my lap. I sprayed the top black so it blened in with my machine.
May 2, 2006. 11:38 AMradiorental says:
velcro
May 2, 2006. 10:43 AMranex says:
is there a way to keep this attached to your laptop so u dont have 2 diffrent item lying around
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:nospleen
I am currently a student.
