Make sure you only use biodegradable laundry detergent labeled for greywater use. Also, there are a few more rules for using greywater so be sure to read those at the end of this instructable.
Remove these ads by
Signing UpStep 1Laundry Greywater Parts
5/8 inch spade drill bit
Garden Hose Adapter 3/4 " MH X 1/2" MIP- part is in the faucet section of Home Depot, not in the garden hose or irrigation area. (Watts brand A-663 GH3) http://www.watts.com/pro/_productsFull.asp?catId=68&parCat=2680&pid=6508&ref=2
'Faucet Rosette Washer and Nut (1/2" IPS) - Danco brand
3/4" diameter garden hose
Trash can (I think mine is 20 gall, but use a larger one)
As for not letting it go where people can come in contact with any soap or sweat from your clothes, heck, they say your detergents are still there after washing and you sleep on your sheets and it gets absorbed into your skin. But that's why he did not put the wash water on the lawn, he didn't want bacteria from the wash on his lawn.
His washer was in the end of the kitchen. He could hear when the machine stopped its first spin and changed the hose over to his recycle tank which was an old galvanized wash pan with a garden hose going out the back door.
I have thought of this the last year, living in Los Angeles also. I like your idea about biogradable detergent and will try it. If it doesn't get my chothes clean as Tide, I'm going to the rince water only method. I'm not wearing grey clothes lol.
Great Instructable :)
But all of that is just icing. You've done a great job with a basic cake recipe. Reproducible, cheap and cheerful. Well done.
as wash water for each load.
Thanks for the information,
desNotes
One of the reasons grey water should not be discharged into storm water drains is because it contains phosphates ( which is found in common fertilisers). However phosphates cause algae blooms if grey water enters rivers and/or lakes.
Grey water must be kept out of the retention pond. Phosphates and nitrates will be be harmfull to any life in the pond. We also use chemicals to clean our tubs and showers and these will also end up in the pond. Used in moderation in the home, this grey water will not effect your garden
Hope this helps
