Simple Light Following Robot
 by Mr.What
Featured
Step 13: Solder motor lead to transistor
Solder the bent drain pin on the transistors to the motor diode lead away from the stripe on it's corresponding motor.
If the two leads cannot reach, or cannot be connected without risk of shorting other leads, use a small length of insulated wire to make the connection.
Repeat for the other NON-stripe motor-diode lead to the corresponding bent transistor drain pin.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
