Simple Line Tensioners for Camping and Backpacking
 by schwieb
Step 4: Drilling the Holes
You can now drill two holes in each piece with your drill (or drill press). Try to get them as even as possible. When you are done you should have something similar to what is pictured below.
Once you have drilled them all, it is also a good idea to spend a little time sanding off the rough parts, saw marks, etc. I also like to round over the corners a little to make them generally less sharp. I think it is worth it because this action will make it less likely that you will snag the tensioner on your cord or line.
gibson_se says: Nov 19, 2009. 10:30 PM
It might be better from a safety and convenience point of view to drill the holes before cutting to final size. Just cut straight strips of plastic the right width, mark out how big you tensioners are going to be, then drill the holes before you cut them apart.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
