Introduction: Simple Marking Guage
Picture of Simple Marking Guage
Rough oak pieces from a cut off branch. Resawn at the time when the branch was cut off and left to dry in the workshop for a couple of years.
Step 1: Preparing Wood
Picture of Preparing Wood
planed down to size and ready for slicing on the table saw.
Step 2: PIeces for the Marking Guage
Picture of PIeces for the Marking Guage
All the pieces are same width and height.
Using the marking bar as template the panel is assembled and glued at a tight fit, where the bar barely can move.
Step 3: Finished Guage
Picture of Finished Guage
Inserting the pin for the makring a hole was predrilled and a small nail was driven through, to make the tip.
Filing the tip to a sharp point is recommended!
Omnivent (author)2016-02-13
Nicely made!
I made a similar gadget, although much smaller (and not particular nice, but hey, it's purpose of making parallel markings is what counts for me), with a hardened tip through a (square) chopstick, a 12x12x30mm pine block with a cut out slightly less the chopstick in height and a small slab of acrylic with two 3mm machine screws in 2.4mm holes to tighten the chopstick.
If you're going to use it on wood, you might consider making a lead- or pencil holder in the end away from the nail.
Have a nice day :)
Neroes (author)Omnivent2016-02-13
Hi,
Thank you for the comment - I will take some of the leftovers and make a bar where a pencil fits through!
I just wanted to share a couple of points. When scribing on wood, the point of a steel tip will go dull much later than a pencil and and make a much more definitive marking. Secondly it will also make a line which your hand tools will follow when cutting. Had I attached a blade, making a knife wall would have been possible.
Cheers
Neroes
Omnivent (author)Neroes2016-02-15
Hi,
Yes, I fully agree on the temporary nature of a pencil, compared to a sharp pointed bit of whatever, but sometimes you need that (at least I do), for markings used for other things than cutting. I used a 2mm piece of spring steel for the point (press fitted), to be able to use a 2mm lead mine if/when need arises.
I attached some pics of the one I made (for small stuff).
Regards
DIY Hacks and How Tos (author)2016-02-13
Great DIY wood tool
About This Instructable
3,234views
72favorites
Bio: Working my way from 0 to 100 documenting the progress all the way. Visit my site at www.plansforanything.com /Søren
More by Neroes:Tablesaw StandQuick Bench Hook From ScrapsSimple Marking Guage
Add instructable to:
