Simple Mini Dusk to Dawn Switch for 220v AC
2,469
51
26
Posted
Introduction: Simple Mini Dusk to Dawn Switch for 220v AC
At or farms, we required to install a few lights that would
automatically turn on at night and turn off at dawn and since we required quite a few, it had to be cost effective and efficient. I thought about installing a timer switch at first but gave up on the idea. Finally after searching through numerous circuits the internet, I figured that an effective, small and cheap circuit could be designed with ease. The entire switch costs under 50 cents (Rupees 31/- in India). I extend my heartfelt thanks and gratitude to all the contributors of the many designs and circuits on the internet from where I have drawn the inspiration, the names of the contributors I do not individually know but my thanks to all.
Step 1: Parts List & Diagram
Parts Required Cost
1” x 1” Strip Board Rs.2/-
1 x BT136 or BTA12 Triac Rs.12/-
1 x DB3 Diac Re.1/-
1 x 1w. 100K Resistor Re.1/-
5mm LDR Rs.10/-
Assorted Wires for wiring Rs.2/-
Old Plastic Film Canister Rs.0/-
Total Parts Cost Rs.28/-
TOOLS
Soldering Iron
Solder Wire
Wire Strippers
Glue Gun
Assorted Small Tools
WARNING
The circuit works on 220v AC and if you are not accustomed to working with mains voltage or do not have ample experience in working with 220v AC Mains Voltage please stay away from this project.
I assume no responsibility for any loss or damage arising directly out of or as a consequence of following this project.
It is always advised to take proper care and precaution while working with AC Mains.
Step 2: The Triac
Step 1.
Cut the strip board to the desired size and trim & file the edeges.
Place the BT136/BTA12 Triac through the holes in the center leaving a couple of lines on either side. Solder and trim.
Step 3: The Diac
Insert the Diac, 1 leg of the Diac should connect to the
Gate of the Triac and the other leg to an empty strip on the strip board, solder and trim.
Step 4: The LDR
Insert the LDR, one leg of the LDR should connect to T1
or M1 of the Triac and the other to the same strip to which the second leg of the Diac is connected, solder and trim.
Step 5: The Resistor
Insert the Resistor as shown in the picture, the first
leg should be connected to the same strip on which the second legs of the Diac and the LDR are connected and the second leg, place across the Triac and connect to an empty strip on the strip board, solder and trim.
Step 6: The Mains Connection
Now connect the Mains Connection Wires.
Connect 2 wires, preferably of the same colour (I have used Black & blue)to the strip on the strip board on which the second leg of the Resistor is connected.
Connect 1 wire (RED) to the strip on the strip board on which the 1st leg (M1) of the Triac is connected
Connect 1 wire (WHITE) to the strip on the strip board on which the 2nd leg (M2) of the Triac is connected. Solder and trim as required
Refer to the drawing for the connections.
Mains Connections –
The Black Wire and the Red Wire go to the Mains AC Supply, this is the input.
The remaining two wires (White & Blue) go to the BULB
Step 7: Done
You can seal the entire circuit in a small plastic
translucent film canister which will keep the water out and also let the LDR function normally in outdoor use.
Thanks for viewing, I must add here that I have been using these circuits on the lamp-posts at our farms for the past couple of months now and they have been connected ever since and I have never had reason to complain as yet. We do have regular power outages for around 4 to 6 hours a day a and that is probably the only rest the circuit gets. Otherwise, the circuit is working as it was intended to and every evening the lights go on and at day break they turn off automatically. I will post pictures of the working lamp-posts ASAP.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    2 Questions
    What is the meaning of DIAC 3
    What is the value of this part
    i have made this diagram same as you described, but it is not working for me, when i switch on the circuit, the light just blink once and turned off, please suggest me what should i do
    20 Comments
    I asked for 1W 100K Resistor. But the shop guy gave me a resistor with color codes of 'Red,Brown,Black and Gold'. Is it ok to use this.
    Red,Brown,Black and Gold is just 21 ohms. 100k is Brown Black Yellow (Gold is the tolerance) and 1 watt is the power handling capacity.
    About LDR: what is the part number? Or, if you don't know that, then what's its rated resistance for daytime?
    I tried with 100k/200k LDR and instead 100k I used 2M - because with 100k the led was on all the time - but even then he was not much sensitive. Are you using 10K LDR or even smaller?
    I'll get back to you on the resistance measurements after physically checking the resistance in the day time.
    The ones I have used are commonly available here and all we have to ask for are 5mm ldr (more commonly known by the size) the resistor value that I have used is not common to all types of ldr that are available and a little bit of experiment is required to figure out what works best for a particular type of Ldr.
    I will take physical readings as soon as I can and post an update on this
    Regards
    I have a question: where do you put the photoresistor in that canister? As far as I tested, if you put a photoresistor into something, it will not work as it should because the canister is not letting enough sunlight in. Or maybe it's different with translucent film canister?
    it works fine with a translucent film container like the ones shown in the pictures.
    Can you please send me the circuit layout
    Here you go. For you and for whoever need it.
    Hello. I like your Circuit. I have a question that if is full moon then it will turn off light?
