Introduction: Simple Mini MagLite Handlebar Holder
Take some scissors to an ordinary 700c bike tube and you've got yourself a dirt cheap way to mount your mini flashlight!
Step 1: Materials Needed
You'll need two very important items:
Scissors
700c or similar sized bike tube
Step 2: Sizing It Down
Find a good section on your tube to cut away. The best possible size I came up with is about two and a quarter times the length of the flashlight.
*Side note: You may want to wash out the powder from the inside. It might be a little messy otherwise.
Step 3: Fitting the Light
From the top end of the tube measure down about one inch, fold it over and cut a slit through the tube.
Make sure the slit is big enough to let the light slide through with some resistance.
From the bottom, turn the tube one quarter rotation, measure down about an inch and a half, cut another slit. This time, the slit must be big enough to let the front end of the light slide through.
The reason for the quarter rotation is because in the end product, if you wrap this around your handlebars correctly, the tube won't be all twisted up.
Now, you're done! Click on for the mounting instructions!
Step 4: Mounting the Light
1. Take the top end of the tube with the smaller slit. Fit it over the back of the light and slide it up to the top of the grip.
2. Hold the light to the handlebar while taking the remaining slack and wrapping it around one and one-half times.
3. Tightly pull the tube up and over the back end of the light, then pull it down and under the handlebar again.
4. Pull the remaining slit over the front part of the flashlight.
Good job!
(If you need any more info on this, ask in the comments!)
The Instructables Book Contest
