Simple Moon Lamp
1,311
16
5
Posted
Introduction: Simple Moon Lamp
Hi All,
For my wife, what can I do if she says, "Please bring me moon from the sky?"
Well I am no astronaut, nor do I have heaps to money to hire one..
An Engineer always finds a way !!!
In this instructable I will share how to make a Paper Mache Moon and bring moon from the sky in your room
Step 1: What Do We Need
Material
  • Tissue Paper ( preferably non textured 2 ply)
  • PVA glue / Fevicol
  • Led Strip
  • LED Driver
  • Wires
  • Electrical plugs etc
  • Basket Ball Size 5
  • Paper tape
  • Cling wrap
Tools
  • Paint brush
  • Pencil
  • Black Acrylic paint
  • Water
  • Paper Cutting knife / blade
  • Soldering iron
Step 2: Dome
To prepare dome we will use a basket ball, one can use balloon as well
Cover the ball using cling wrap and use paper tape to mark a reference around the ball. We will cover tissue paper till this reference, it needs to be smaller than the diameter, to enable us to remove the dome easily later.
In a large pan mix PVA glue or fevicol with water ( 1:1 ratio) Using large paint brush spread it over the ball and place tissue papers to cover the ball till the reference paper tape mark.
In my first attempt, I did 5 layers and after paint job etc, it was opaque...
So in the second attempt I covered 3 layers only .... Let the dome dry for 12 hrs atleast
Step 3: Paint Job
Demold or remove the dome, carefully from the basket ball. If you tear it a little, then use tissue paper and patch it, set it to dry for few hours
Draw a reference carter shapes, one can use internet to get the right shapes.
Using black acrylic paint with excess water, paint the carters.. Caution : Too much of water will melt the tissue paper.
I lost some dome shape here due to water... I let it dry for few hours after paint an then coated a layer of PVA glue or fevicol ( Do not add any water ). AGain let it dry for few hours....
Step 4: Back Cover
Back cover : Measure diameter of the dome and cut a cardboard circle that slides inside the dome about 1 mm.
Note that I tried to create phases of moon but the cardboard partitions were too small. May be I will make it in next version
Electronics :
Paste few pieces of LED Strips in curved lines as shown. Connect all -ve and +ve to the LED driver circuit.
Connect the AC in to a power plug best suited to your requirement
Note : Usually, I solder all connections and cover it using heat shrink tubes, this give strength to the connections
Step 5: Final Touches
Using Glue gun stick the back cover to the dome. Hang it on the wall and enjoy moon light indoors
Improvements
  • To have moon phases, need to increase height of internally partitions
  • Use Acrylic dome to have stronger structure
  • Paint job need someone better who could paint it
Please share your comments
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    5 Comments
    That is awesome! My son would love something like this. He is crazy about all things space.
    my first attempt, 4 layers and thick acrylic paint, gave me this... looked like planet ?
    Thanks... My son is my inspiration
    Cool!!! I made a similar one a few years ago. It operated on a 9v battery. Unfortunately, it cracked. I still have the salvaged parts left with me ;)
