Simple No-Weld Bike Trailer by mr.mcninja
Featured
Step 3: Wheel Assembly
After much consideration, I determined the best way to fix 26 inch mountain bike wheels to the trike frame.  Your trike design may differ, but the Micro Spinmove has caps at each end of the perpendicular frame tube.  It originally had a rod that extended through its length which was the axle that the plastic tires spun on.
First remove and discard the axle.
Then removed each end cap from the frame.
Connect the caps to the length of threaded bolt extending from the hub of each wheel using a washer and nut.
Just fit the caps back in to the perpendicular tube of the frame and you're rolling!
You may be asking what keeps the end caps from flying off during use.  Friction alone is not good enough.  What I did was have my local hardware store cut and thread a rod that extends from one wheel to the other and replaces the bolts that ran through the center of each wheel hub.  When I screwed a nut to each end, the wheel hubs stay firmly in place, allowing the tires to spin freely.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
