Introduction: // URBAN DIY // Simple Outdoor Chair
Disclosure: Some of the links below are affiliate links, meaning at no additional cost to you, I will earn a commission if you click through and make a purchase.
This plywood outdoor chair is very easy to build and you can get all the materials from your local department store. If you don`t need anything fancy, you are on a low budget and really could use an extra chair outside, then this is the project for you.
You will get more details in the video we made for you. If you like this project, you can support us by subscribing to our YouTube channel. All the likes and shares are very appreciated too :)
TOOLS TOGETHER
Step 1: Things You Need
You will need:
Plywood sticks 35 x 35 mm
Screws
14 Mounting brackets to the screws
Outdoor oil or polisher.
About 30 meters of elastic band
Tools:
Clamps https://amzn.to/2M13SBN
Sander plus 120- and 180-grit sanding pads https://amzn.to/2ztGuog
Circular saw or table saw https://amzn.to/2P7vDFr
Drill / Driver plus assorted bits
The video was filmed with following equipments:
Camera https://amzn.to/2zuNHEp
Lens 1 https://amzn.to/2DMEM4i
Lens 2 https://amzn.to/2P9BGtj
Field monitor: https://amzn.to/2Q1yyEO
Tripod: https://amzn.to/2KISHda
Step 2: Cutting the Pieces
First cut all the pieces using a table saw.
Four pieces are going to have to be cut under 45 degrees. These will be the chairs legs.
Step 3: Installing the Chair
For installing all the pieces together you need a glue and a drill. First mark the points for the screws then confirm the screws using a drill. To improve the glues effect cut the stripes to the places you want to glue using a paper knife.
Step 4:
Sand all the surfaces. You do not necessary need a sander for that, a regular sand paper will do the job too.
Step 5: Finishing
Cover all the surfaces with the water proof polisher. This is very important if you want your chair last longer than one season. Let it dry.
Step 6:
You may use a wood plate for the sitting place but you could also braid it. For that you will need an elastic band. Watch the video to see the exact technique.
