Introduction: Simple PWM Control (555) for Motor's, Lights, Heated Clothes, Etc
I dont intend to go into the ins and outs of this circuit, just how to make it. you can save pennies by using reclaimed components from old circiut boards but these parts are all cheap and readiy available. The Circuit here is 144Hz and R2 (10k) is not needed for my needs, The circuit below is for a fan and R2 switches the fan on in a PWM failure ie fail safe.
The PWM cct only uses 1ma
Parts
Strip Board
1 x 100 nf Capaitor
1 x 1 uf Capaitor
1 x 555 timer chip
1 x 8 pin socket (optional)
2 x diodes (not zenner)
1 x 100k Potentiometer
22 awg wire
Transister (suitable for your project)
Project box.
Tools
wire cutters
solder
soldering iron
5mm drill bit
saw
Parts
Strip Board
1 x 100 nf Capaitor
1 x 1 uf Capaitor
1 x 555 timer chip
22 awg wire
Project box.
Tools
wire cutters
solder
soldering iron
5mm drill bit
saw
Step 1: Prepare Strip Board
Strip board consists of copper strips with holes predrilled at 1/10 inch pitch. The components sit on the plain side the legs then solder to the tracks.
The tracks under the ic will need cutting to do this a 5mm drill bit is used this will remove the copper track where it is needed.
For this project we will use a small piece of strip board 12 strips wide and 1 1/2 inch long.
Remember when cutting the tracks the underside is in reverse
Step 2: Add Components
First Prepare the Potentiometer, cut 3 equal lengths of wire aprox 2 inch long strip of 4mm of insulation from all ends and sold one piece to each of the 3 pot terminals.
When soldering components it is good practice to solder the lowest profile components first, and where possible keep components flush to the board
we shall start with 22 awg wire links
next to solder are the diodes note there direction
followed by IC or socket and capacitors. (if using a IC socket remember to insert the IC at the end)
Finaly the Transister, Pot wires and supply wires. (Check pin out of transister that you are using)
Step 3: Testing
connect the suply wires to power source 5v to 15v should do observe the correct polarity +ve to +ve etc. during testing check that components dont get hot.
The only component that may get hot is the transister under full load if neccersary fit suitable heat sink.
By swapping the min max pot ends changes the direction of rotation for off to full on.
Scope
probe the gate pin or base pin on the transister and rotate the pot from one extreme to the other and finaly centre, Check that the pwm signal is square wave and that the duty cycle changes apropriatly.
Frequency Meter & LED
probe the gate pin or base pin on the transister and rotate the pot from one extreme to the other and finaly centre the frequancy (aprox 10 Hz) should change but not significantly this is a function of the RC on the 555. True PWM the frequency is constant.
Take a suitable Load (LED and resister in series) and connect across the output turn the pot from extreme to extreme again LED should brighten and Dim accordingly.
Power Testing
To test under power a siutably rated load should be used as Im looking at using an approx 3ohm load (ie the heater cable) wire up and start test on low PWM checking the tempreture of the transister. Idealy the transister shouldnt go above ambient tempreture any power loss ie heat in the transister isnt power in the heater.
Step 4: Clothes Heater Wire
As I am interested on using these on my Motor Bike I have placed the heater where I feel the cold the most. The photos were taken before i fitted inline 5.5mm power Jacks.
I have now finished this project unfortunatly the IRF1730 TO-220 over heated and the wire didnt, However I found an smd AO4406 on a trashed laptop motherboard it works fine
