Simple Pi Robot
6,409
95
Posted
Introduction: Simple Pi Robot
Simple Pi Robot aims to put robot control in simple form, the robot design is similar to versatile GOPIGO robot built by dexter industries.
The part list
(1) Raspberry pi (Any model) but with the recent launch of pizero or pi 2 shall be a good option, my current model employs B+
(2) 40 pin GPIO cable (if using pi B+ or pi 2)
(3) Breadboard (for quickly assembly various sensors)
(4) A 2wd chassis
(5) Distance sensor (Ultrasonic HC SR04)r
(6) Power bank (for powering up the pi)
(7) Rechargeable batteries AA (preferably 2100 mAH)
(8)Jumper wires both Male & female type, Resistors
(9) WiFi adapter (EDUP/EDIMAX for communicating wirelesly with pi)
(10) Memory card (4GB and higher for running the OS on pi)
(11)Motor drivers (L298 )
(12)servo motor
(13) Miscellaneous - cable ties (for tying the jumper wires) and foam tape (for holding servo or any other sensor where screw assembly cannot be used)
Step 1: Choosing the Motor Drive Shield
Currently there are very few motor drive shield available for raspberry pi, to name some
(1) RTK Motor controller shield - RTK Motor control shield
(2) Pololu DRV8835 Dual Motor Driver Kit for Raspberry Pi - Pololu DC motor shield
(3) Adafruit DC and Stepper Motor HAT for Raspberry P- iDC Motor Hat for Raspberry pi
(4)Raspirobot board made by Adafruit - Raspirobot Board
and recently underdevelopment like ZEROBORG - ZEROBORG
One of the most common problem building any robot is to minimize the wiring requirement and the same can be achieved by using the shields/hat. I tried building my robot first with one of the shield equivalent to Raspirobot from the manufacture ALSROBOT the kits ships from china but the problem was i was unable to increase the motor input voltage from the board the maximum was less than 5 Volts, with slight unbalance between the voltages, still one can check the following link - ALSROBOT - PI Motor driver shield
Anyhow In my current tutorial i have used the cheap and versatile L298 motor driver - L298
The advantage with the above board apart from being cheap is that there is regulated 5Volts output is available.
I have used the L298 board to drive two DC motors and 1 servo motors
Step 2: The L298 Motor Driver
I have Mounted L298 Motor driver at the the bottom of my chassis, now to connect the DC motor and servo motor connect (i) DC Motor -A to output -A (+ & -)
(ii) DC Motor -B to output -B (+ & -)
(iii) Servo motor +ve to + 5V regulated supply of L298 Board & servo motor -ve to GND of L298 Board
keep the enable pin jumper as it is if you don't want speed control else remove the jumper, the jumper in place ensures +5V supply to enable pin which in turn drives motor at rated speed.
Now connect 4 nos jumper wires to the control inputs, connect other end of jumper wires to GPIO pin as designated in next step.
For servo motor connect one no jumper wire for control to GPIO pin as in next step
Step 3: The Servo Motor
The servo has a 3 wire connection: power, ground, and control. The power source must be constantly applied
The control signal is pulse width modulated (PWM), but here the duration of the positive-going pulse determines the position of the servo shaft. For instance, a 1.520 millisecond pulse is the center position for a Futaba S148 servo. A longer pulse makes the servo turn to a clockwise-from-center position, and a shorter pulse makes the servo turn to a counter-clockwise-from-center position.
I have used Futuba s3003 servo - the connection is very simple the "+" & "-" goes to the L298 Board as outlined earlier. Its important to look at the operating voltage of servo ( in my case its 4.8 - 6 V see image above), the signal wire is to be connected to GPIO output , normally its white or orange
Controlling servo motors in raspberry pi might be tricky but then there is very powerful library hosted @ RPIO.PWM ,to install it on pi use the following code
sudo apt-get install python-setuptools
sudo easy_install -U RPIO
To know more about RPIO.PWM and the DMA used , please refer to the link https://pythonhosted.org/RPIO/pwm_py.html
Step 4: The Robot Chasis
I have used Ellipzo Robot chassis with 2wd, 2wd are simple and easy to control to get started with lots of coding.
The kit comes included with DC Motors, pan kit for servo motors and all necessary hardware's to assemble the kit
The detailed link is available at - Ellipzo Robot chaisis kit
Pl refer to video for assembly of Raspberry Pi, along with L298 motor driver, the Breakout board , camera module and the power bank.
Step 5: The Distance Sensor
Integrating the distance sensor is easy and we need just 1k resistor along with jumper wires. Connect VCC & GND to pi +5Volts & GND respectively.
The other two pins TRIG & ECHO are to be connected to GPIO pins as in preceding steps
Remember to connect the resistor as shown in image.
The Python code to measure distance is included in the last step.
Step 6: Raspberry Pi -camera - Video Streaming Using VLC Player
Here I have used Pi camera module , the set up is quite easy and you can refer the link :Raspberry pi Camera setup
For video streaming, with VLC begin with installing VLC on raspberry pi
sudo apt-get install vlc
To start streaming the Camera Video Using RTSP enter following
raspivid -o - -t 0 -n | cvlc -vvv stream:///dev/stdin --sout '#rtp{sdp=rtsp://:8554/}' :demux=h264
or with proper width & height use following code
raspivid -o - -t 0 -n -w 600 -h 400 -fps 12 | cvlc -vvv stream:///dev/stdin --sout '#rtp{sdp=rtsp://:8554/}' :demux=h264
Now to view the stream over VLC player open VLC on your remote system than open a network stream using
rtsp://###.###.###.###:8554/
where ###.###.###.### is the address of your pi given by the network router.
Now as the pi moves inside your home see the video stream on your remote system.
Step 7: Raspberry Pi Pin-out & Python Code
Step 8: Some Assembly Images
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    2 Comments
    Hi I am making the ultrasonic sensor part of this and I am running into a few issues. My first question is, does the resistor size matter? I have a 1 watt and a 1/4 watt which one do I use? Secondly when I run the code for the ultrasonic sensor it says "waiting For Sensor" but nothing shows up. I need help ASAP can someone please help me????
    Hi
    well, yes resistor rating is important, typically resistor with same wattage rating may have different ohmic value, so instead go with the ohmic value. Add 1k ohm resistor between the echo pin and GPIO as in above. (To know resistor is 1k, you can refer to colour coding chart or measure with multi-meter).
    Waiting for sensor is due to improper value at Echo pin.
    Let me know, if you face further trouble, if any.
