Simple Plywood Box... by butynski
Featured
Step 2: Simple Plywood Box...
Next move over to the chop saw, we are going to cut the miters on the chop saw. Set the chop saw to 45 degrees. next set up a stop block, you want each one of the cuts are the same length. If the sides of the boxes are a little off, it will not line up, when you are ready to glue and nail the corners. Keep in mind when you are using a stop block you want to hold the martial on the side of the stop.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
