loading
Step 3: Simple Plywood Box...
Next glue up. Lay out 4 piece in the order that you want them. Put masking tape on the outside of the wood, you do not want to any space between the wood. flip over the pieces of wood, add glue to the miter joints. Fold up the side, so you get a box.
in the corners, use the finish nail gun and add two nails to each corner.
<p>To make a box with a lid, just add the top same as you did the bottom (but use at least 1/4&quot; plywood, not 1/8&quot; which is not strong enough to support the weight if the box is holding over a pound or two when loaded). Once the glue is all dry, you can cut the top off the box using the table saw. Hinges and handles are then easily attached for a very handy box. I made several of them over the years to hold my hand-held power tools. Most of them are made entirely of 1/4&quot; plywood with triangular pieces glued on the inside corners to add strength.</p>
These are nice boxes. There are simpler ways to make them. To begin with any time I need to make something from plywood, I go to Craftwood Lumber in my town. They do all the cutting per specs I give them. And they sell half and quarter sheets. <br>So someone with few tools need not be discouraged. Simple can be yet simpler and be more accessible.
cool box! what time of plywood is that and how did you paint it. i like that color
Baltic Birch plywood, with no finish on it.
You were right, it is simple....but also elegant in it's simplicity. <br> <br>Nice Work
About This Instructable
132,935views
194favorites
License:
More by butynski:Laser Etched Gears at differnt depths...techshop Simple Plywood Box... Finishing wood with 100% pure Tung oil, using the Hub at Techshop.
Add instructable to:
