loading
A simple way to start the Raspberry Pi programming way is try to programming a Raspberry Pi. Now I have created this simple tutorial. You can follow the simple passages and make a simple RGB wireless lamp.
All the components are a RGB led, comune cathode, three resistences (120 Ohm + 120 Ohm + 100 Ohm), a pinplug for Raspberry Pi GPiO, and a piece of perfboard.
Materials
You can also buy this RGB led with resistors
Step 1: The Circuit
The circuit is very simple. You can also use a breadboard and some jumper cable.
Follow the scheme, and solder the components on the perfboard. Use a RGB common cathode and 3 resistor. Use the 120 Ohm resistor for blue and green pin and 100 Ohm for red pin.
About This Instructable
3,585views
31favorites
License:
More by masteruan:House's Monitoring Consumption With Arduino UNO Arduino 101 Bluethooth IOS Pulse Sensor C51 4-Bit Clock Kit 3D Printed Enclosure
Add instructable to:
