Simple Bluetooth RC Car (Arduino Nano + HC-05)
4,288
15
Published
Introduction: Simple Bluetooth RC Car (Arduino Nano + HC-05)
About: Lazy Software Developer
I will share my simple project on how to use your android phone to control robot car.
Step 1: The Hardware
  • 1 x Arduino Nano
  • 1 x HC-05 Bluetooth module
  • 1 x Motor Driver Module (TB6612FNG)
  • 2 x Motors ( with Wheel)
  • 1 x Battery for Arduino
  • 2 x Battery for Motors
Step 2: Connections
Arduino - HC-05
  • D11 - Rx
  • D10 - Tx
  • +5v - VCC
  • GND - GND
Arduino - TB6612FNG
  • D3 - PWMA
  • D4 - AIN2
  • D5 - AIN1
  • D6 - STBY
  • D7 - BIN1
  • D8 - BIN2
  • D9 - PWMB
  • GND - GND
TB6612FNG - Battery
  • GND to V-
  • VM to V+
Arduino - LED (Optional)
  • D13 - LED+
  • GND - LED-
Step 3: Codding
/* RC_Bluetooth_2018_v6<br> * By:    Khamlek HOMSOMBATH
 * Date:  Jan 17, 2018
 * Download Controller for Android : <a href="https://play.google.com/store/apps/details?id=com.lekpkd.duinojoy">  https://play.google.com/store/apps/details?id=com...>
#include <softwareserial.h></softwareserial.h><SoftwareSerial.h>
// arduino>>bluetooth
// D10 (as RX)   >>>  Tx
// D11 (as TX)  >>>  Rx
SoftwareSerial bluetooth(10, 11); // RX, TX
#define ledpin 13 // Connected to LED
#define PWMA 3
#define AIN2 4
#define AIN1 5
#define STBY 6
#define BIN1 7
#define BIN2 8
#define PWMB 9
void setup() {
  Serial.begin(19200);
  bluetooth.begin(9600);
  pinMode(ledpin,OUTPUT);
  pinMode(PWMA,OUTPUT); // PWM A
  pinMode(PWMB,OUTPUT); // PWM B
  pinMode(BIN1,OUTPUT); // B
  pinMode(BIN2,OUTPUT); // B
  pinMode(AIN1,OUTPUT); // A
  pinMode(AIN2,OUTPUT); // A
  pinMode(STBY,OUTPUT); // STBY
  digitalWrite(STBY,1);
analogWrite(PWMA, 0);
  analogWrite(PWMB, 0);
String data = "";
void loop() {
  while(bluetooth.available()){
    char a = bluetooth.read();
    if(a==')') {
      setData(data);
      data = "";
      return;
    data += a;
int ledVal = 0;
void setData(String data){
  data.trim();
  int index = data.indexOf(",");
  if(index != -1){
    int angle = data.substring(0,index).toInt();
    int strength = data.substring(index + 1).toInt();
    digitalWrite(BIN1,0);
    digitalWrite(BIN2,0);
    digitalWrite(AIN1,0);
    digitalWrite(AIN2,0);
    if (angle < 180){
      digitalWrite(BIN1,1);
      digitalWrite(AIN1,1);
      if(angle < 90){
        analogWrite(PWMA, strength * 255 / 100);
        analogWrite(PWMB, strength * (angle * 255 / 90) / 100);
      }else if(angle > 90){
        analogWrite(PWMA, strength * ((180 - angle) * 255 / 90) / 100);
        analogWrite(PWMB, strength * 255 / 100);
      }else{
    }else if(angle > 180){
      digitalWrite(BIN2,1);
      digitalWrite(AIN2,1);
      if(angle > 270){
        analogWrite(PWMB, strength * ((360 - angle) * 255 / 90) / 100);
      }else if(angle < 270){
        analogWrite(PWMA, strength * ((90 - (270 - angle)) * 255 / 90) / 100);
      }else{
    return;
  if(data.equals("a")){
    if(ledVal==1) ledVal=0; else ledVal=1;
    digitalWrite(ledpin, ledVal);
    return;
  Serial.print("Recieved: ");
  Serial.println(data);
Step 4: Testing
Please download Duino Joy Android App at
https://play.google.com/store/apps/details?id=com....
  1. Pair your Arduino Car to your Mobile phone in bluetooth setting on your phone
  2. Open Duino Joy app
  3. Click 'Connect' button
  4. Select 'HC-05' or any name you set for your HC-05
  5. Let's play!!
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    3 Questions
    1.Hola genio! Estoy armando uno, con un motor de destornillador electrico, una placa nano, el modulo y el controlador de motor, me podrías pasar una configuracion de arduino para que funcione con tu app? tambien pienso implementar leds! desde ya gracias
    Hi, I don't understand Spanish, but hoe this help.
    You can test Arduino with my app by Simple code below:
    #include <SoftwareSerial.h>
    // Arduino >>> bluetooth
    void setup() {
    Serial.begin(19200); // Display to Arduino IDE Serial Monitor
    bluetooth.begin(9600); // Communicate with Bluetooth module
    void loop() {
    while(bluetooth.available()) // Wait for data from bluetooth
    char a = bluetooth.read(); // Read Data as Char from Software Serial
    Serial.println(a); // Print data to Serial Monitor
    Could you please make one with l9110s module. I have tried making with different drivers such as l293d but i failed. At the moment i have arduino nano and l9110s but i keep failing again and again. Am totally new to connections and coding but tutorials didnt help either. Need help!
    Sir could you explain the black wire coming from 9v to TB6612FNG and from there to the bluetooth module. What is that connection? Please help as its not provided in the above procedure.
    Hi,
    Thank you for comment, These are GND connection, you can link from Arduino to Bluetooth module directly.
