3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple RGB Cold Cathode Light
This project started because I needed a 90 degree HDMI adapter but just couldn't bear to leave Monoprice with only a $3 very boring widget. So, after combing around for a while I found these cold cathode tubes designed for lighting up your PC. I bought one each in red, green and blue and after about 20 minutes of assembly had a pretty decent little lamp. Total cost was about $25-30.
Shall we begin?
Step 1Materials List
Materials List
This is a very simple project so all you'll need is:
- Red cold cathode tube kit
- Green cold cathode tube kit
- Blue cold cathode tube kit
- 12V DC power supply
- Scotch tape
- Electrical tape
- Foam insulation tape
- Translucent tube of your choice
Notes:
The cold cathode kits I had included an inverter, a switch, and all the wiring. They're designed to simply plug in to your desktop's molex connectors so they should be all ready to go.
The red kit had 2 lamps included which worked out for building but gives the light a pinkish hue when in white mode.
The tube I used was from the center of a roll of large format printer paper. It is a translucent, whitish plastic with small striations along the length.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:drips
