Introduction: Simple RJ45 DB9 Cisco Console Cable
Hello everyone,
I just bought my first cisco router (2610) and, in order to learn about it I decide to start a blog. The idea its to provide a step-by-step from nothing to something that can be useful in a SOHO environment. The blog still in the very early steps, but it will be the experience of my interaction with my cisco router. here the URL: http://cisco4dummies.blogspot.com
I bought my router online (craigslist) and it came without the console cable. Looking around I found many articles talking about build your own cable but none as simple and easy as I wanted to be. Many articles describe adapter, mini cables, etc, and I was just looking for some straight, simple, easy do understand instructions.
This instructable is my attempt to provide the level of information I was looking for myself.
Step 1: Getting Started - Bill of Material
First we start with the parts:
- Cat5e cable (mine has 6ft.);
- 1 RJ45 Connector;
- 1 DB9 Connector;
- Crimp tool;
- Soldering Iron.
Step 2: Crimping the RJ45 Connector
Lets start crimping the RJ45 connector. I personally use TIA/EIA 568A wiring diagram to all my cables, so I will continue doing so:
If you never crimped a RJ45 before, please refer to this video:
(credit: video from cablesupply.com)
There are many videos/sites showing how to crimp.
Just make sure you follow, in this case, TIA/EIA 568A wiring diagram
Step 3: Connectiing the DB9
The following diagram shows how each cable, by color, should be connected:
CAT5 DB9 Pin
Green-White 8
Green 6
Orange-White 2
Blue 5
Blue-White 5
Orange 3
Brown-White 4
Brown 7
The Blue/White and Blue must both connect to pin 5 on the DB9. Pins 1 and 9 are not connected.
This is the RS232 Pins assignment (for reference)
Pin 1 - Received Line Signal Detector (Data Carrier Detect)
Pin 2 - Received Data
Pin 3 - Transmit Data
Pin 4 - Data Terminal Ready
Pin 5 - Signal Ground
Pin 6 - Data Set Ready
Pin 7 - Request To Send
Pin 8 - Clear To Send
Pin 9 - Ring Indicator
Step 4: Done
That's it.
Cant be simpler than that.
cheers
PC
