Simple Red Laser
Introduction: Simple Red Laser
Hi friends. Today in this instructable, I am going to show you how to make simple red laser. You must have seen that lasers require a lot of complex circuits using various types of ICs and transistors. Today, in this instructables, we are going to make a very simple laser which will cost you less. So lets start making the laser !!!
Step 1: Components Required
1.) L7806
2.) 10 ohm resistor (2)
3.) 100 ohm resistor
4.) 10k ohm resistor
5.) red laser diode
6.) Battery cap/clip
7.) 9 volt battery
8.) Dot board
Step 2: The Tools
1.) Soldering gun
2.) Soldering metal
3.) Power source
Step 3: The Circuit
Step 4: Solder the Components
If you want to make it beautiful, you can put it in a small box and decorate it.
Step 5: Testing !
Press the battery clip/cap on the battery and the laser will be on. Ensure that the laser diode do not become hot. If it is becoming hot, see that you have connected the 10k ohm resistor correctly.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
