3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Relay Shield for Arduino
Shield to control 6 relay, 6 digital input and 6 analog input with Arduino Duemilanove, Arduino UNO. The digital inputs and relay outputs are equipped with an LED that indicates the status.
The circuit diagram is very simple:
Step 1Schematics and PCB
Schematics and PCB
In this step you can find the circuit diagram and the PCB file.
All the digital input are protected by a diode, the analog input are protected by a zener diode.
BOM Arduino - IN/OUT
R1: 1 kohm
R2: 1 kohm
R3: 1 kohm
R4: 1 kohm
R5: 1 kohm
R6: 1 kohm
R7: 4,7 kohm
R8: 10 kohm
R9: 4,7 kohm
R10: 10 kohm
R11: 4,7 kohm
R12: 10 kohm
R13: 4,7 kohm
R14: 10 kohm
R15: 4,7 kohm
R16: 10 kohm
R17: 4,7 kohm
R18: 10 kohm
R19: 470 ohm
R20: 470 ohm
R21: 470 ohm
R22: 470 ohm
R23: 470 ohm
R24: 470 ohm
R25: 4,7 kohm
R26: 4,7 kohm
R27: 4,7 kohm
R28: 4,7 kohm
R29: 4,7 kohm
R30: 4,7 kohm
C1: 100 µF 25 VL el
C2: 100 nF
D1: 1N4148
D2: 1N4148
D3: 1N4148
D4: 1N4148
D5: 1N4148
D6: 1N4148
D7: 1N4148
D8: 1N4148
D9: 1N4148
D10: 1N4148
D11: 1N4148
D12: 1N4148
DZ1: Zener 5,1V 400 mW
DZ2: Zener 5,1V 400 mW
DZ3: Zener 5,1V 400 mW
DZ4: Zener 5,1V 400 mW
DZ5: Zener 5,1V 400 mW
DZ6: Zener 5,1V 400 mW
LD1: Led 3 mm red
LD2: Led 3 mm red
LD3: Led 3 mm red
LD4: Led 3 mm red
LD5: Led 3 mm red
LD6: Led 3 mm red
LD7: Led 3 mm green
LD8: Led 3 mm green
LD9: Led 3 mm green
LD10: Led 3 mm green
LD11: Led 3 mm green
LD12: Led 3 mm green
T1: BC547
T2: BC547
T3: BC547
T4: BC547
T5: BC547
T6: BC547
RL1: mini relay 12V
RL2: mini relay 12V
RL3: mini relay 12V
RL4: mini relay 12V
RL5: mini relay 12V
RL6: mini relay 12V
Misc:
- Screw connector 2 via 2,54 mm (8 pz.)
- Screw connector 3 via 2,54 mm (6 pz.)
- Strip 8 via 12 mm (3 pz.)
- Strip 6 via 12 mm
- PCB
7 comments
Mar 17, 2012. 8:42 PMviranha says:
awe some, I can make PLC with this board.
Sep 3, 2011. 7:58 PMkmpres says:
Nicely laid out board. Could be just what I need.  I need to know two things:
1.  How much AC current can each contact take? I want to use them to switch 100 W lamps on and off .
2.  Can the relays pick at 5V?  I wish to run my arduino and the relay shield off of an old cell phone battery charger, rated 5.6V, 300ma.
Why is it that no one seems to be making 6V relay shields these days?
When possible, I prefer to use cell phone battery chargers because they are tiny and rated for long term use.  Much better than lugging a 12V power supply around and burning off the excess voltage with regulators.
Mar 30, 2011. 6:45 PMBuild_it_Bob says:
Very well laid out . Very nice the way you placed a lot of components into a small area. Keeping all the output contacts together on one side of the board is great for isolation as well. Thanks for the ible !
Build_it_Bob
Mar 7, 2011. 5:40 PMzazenergy says:
Cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:technolando(Open Electronics)
