3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Sequencer
Step 1Go get stuff
Go get stuff
You will need:
- (8) 1M potentiometers
- (8) 50K potentiometers
- (8) 10K potentiometers
- (8) SPST 5V relays
- (1) 20K potentiometers
- (16) .1uF capacitors
- (16) 220 ohm resistor
- 74HC595 Shift Register
- Lamp pull switch
- M-type power adapter
- Mono audio jack
- 10K resistor
- 16F877 Pic chip
- 20 MHZ resonator
- PCB or two
- 40 pin socket
- Mat board
- 12 x 12 sheet of acrylic
- Wood grain contact paper
- 5 x 7 aluminum box
- An analog variable resistance based noise maker
- Rubber feet
- 26 knobs of various color
- A power drill
- C-clamps
- An awesome Epilog laser cutter
- A soldering setup
- Misc tools and hardware
1 comment
Jun 26, 2009. 6:28 PMamplex says:
not to steal your thunder, OP, but for those interested in a MUCH much simpler (and also usable as a CV sequencer!) do a google search on Baby10 sequencer. No PIC required, just a simple 4017 (for 10 steps) or 4022 (for 8 steps), the 8 100k pots, 8 1n4148 diodes, and some leds and resistors if youd like. i can build these in an hour, and have put them in toy drums, synths, etc!
Dec 6, 2009. 10:10 AMteeps says:
 Would you please make an instructable for this?  I would love to see it.  I am interested in all of this stuff!
Dec 6, 2009. 11:15 AMamplex says:
I've had parts around to do a 16 step one for awhile, a very simple project with 3 chips (40106 timer, 2x 4022 or 4017), 16 diodes, 18 pots, leds+resistors.  It will have CV out with a pot to control the range, and 1 for gain (internal osc). I'll start working on it tonight.  The only thing I've never done is make a drawn schematic for it but its based on the common Baby10 schematic which you can search for.
Dec 6, 2009. 1:27 PMteeps says:
Sweet!  Sounds awesome.  I can't wait to see it.  If you make everything else clear enough, the schematic might not be too big of a hurdle.  But then again, it might be a fun challenge that would hone your skills in an area that's not a strength at the moment.   :)
And on a separate note that I should have included in my first comment:  I really like THIS instructable as well, great job!
Sep 21, 2010. 10:13 AMarmenws says:
http://www.flickr.com/photos/armenws/4796997608/
here's a 16 step sequencer schematic.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2357
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
