Use it to check your servos before installing them into your models or to center your servos when setting up linkages. The Simple Servo Tester can also be tuned to precisely center your servos - Some manufactures consider 1.520 milliseconds to be center while others use 1.500 milliseconds.
Use it anytime you want to operate a servo but don't want to get out your RC equipment!
This project was designed by W9GFO. You can get the kit from Gadget Gangster and download a PDF version of this howto.
Warm up your soldering iron and get started!
Remove these ads by
Signing UpStep 1Make: Parts List
Parts list
- Potentiometer Knob
- Green LED
- NPN Transistor
- Right angle pin header (9 pins)
- 555 Timer Chip
- 20k Right Angle Potentiometer
- Trim pot
- 2x Capacitors (0.1 uF)
- Rectifier
- Custom PCB
- 220k ohm resistor (Red-Red-Yellow)
- 3x 10k ohm resistor (Brown-Black-Orange)
Thanks to Dustin for pointing out the omission.
Rich H
I'll agree that it is good practice to save the chips until the end but for this board there are so few components that it really makes no difference. I also usually like to start with the lowest height components first, but again, this board is small enough that it is easier to just start in the middle and work outwards.
However, for anyone concerned about burning up the 555 chip, go ahead and put it in last, there is no reason why that wouldn't work just as well.
Rich H
Anyway, I just solder on an IC socket first, then transistors, because they have pins so close together. It's hard to solder around a tone of resistors, capacitors, etc, as my soldering iron tip is not quite what it sould be. (it hits other stuff because of its thickness, very annoying)
Just a thought.....
In other words, the tester itself wouldn't need the regulator but the servos might. If you power the servo tester with a battery that is a higher voltage than your servos are rated for, you run the risk of damaging your servos.
Rich H
In 4910, I guarantee 5 volts to the servos.
if they don't provide the "Custom PCB" information so we can etch one ourselves, this is just an advertizement
and its featured?
what the hell
Rich H
http://www.ecelab.com/circuit-astable-555.htm
i have NO idea why i never thought of the painter's tape idea when soldering junk onto something like this (again...me=electronics N00B10)...that's such a simple idea
The 555 timer is one of the most classic, ubiquitous integrated circuits - the wikipedia article is a pretty good read.
