Simple, Single Folding Key
12,453
359
20
Published
Introduction: Simple, Single Folding Key
About: Welcome to Verticees Papercraft. I am specialize in paper model design. You can view all my work at my website: cartesiadesign.com, or at my Etsy shop, www.etsy.com/shop/Verticees. Thanks for viewing!
Now that it's summer, I go out running everyday. Before I leave, I have to make sure I get my house key so I can lock up the house. While running, I had to hold my key in my hand (I blame my pocketless shorts), and I would frequently drop it. I dropped it so much that my key actually bent a little bit! To stop this, I made a folding key holder which would not only protect my key, but make it much cooler!
This is a short and easy project, so I'm glad to say that each step requires very little description! Hope you like making it!
Step 1: Get Materials and Tools
Luckily, not too many pieces are required for this simple project. Most of the metal parts I used were from some pieces I found from an Erector Set (excluding the washers). For this project, you will need the following pieces:
  • 2x 2.5 in. flexible blue flats
  • 2x 1 in. screws
  • 2x 1/4 in. washers
  • 4x thick rubber spacers
  • 2x thin clear rubber spacers
  • 4x square nuts
  • 1x your house key
You will also need the following tools:
  • Allen wrench (for screws)
  • Wrench (for nuts)
  • Pliers (optional but helpful)
That's all you need!
Step 2: Begin Assembly
First, put the two screws through the two end holes of one blue piece.
Step 3: Put on the Spacers
Next, get two of the thick rubber spacers. Push them down on the screws as far down as they will go. Make sure to do it on both sides!
Step 4: Put on Clear Spacers on the Right Side
Now, get your two clear rubber spacers. Push both of them onto the RIGHT screw. Make sure they are down as tightly as possible.
Step 5: Put on the Washers and Key
For this step, you'll need the two washers and your key. Put one washer onto the LEFT screw. Next, put the key on, and the second washer on top. Check the last picture on this step to make sure everything is stacked correctly as of now.
Step 6: Put on the Last Two Spacers
Now, put your remaining two spacers onto the screws. Push them down as far as possible, and make sure there is still extra room at the top of the screws.
Step 7: Put on the Flexible Piece
All you have to do in this step is put on the last flexible piece on top. Make sure the holes on the piece align with the screws.
Step 8: Put on the First Nut Layer
Now, we need to secure all the pieces down together. To do this, we'll need two of the four square nuts. Using the Allen wrench as well as the normal wrench, tighten the nut down so that about 2 millimeters of the screw can still be seen.
Step 9: The Final Nut Layer
To finish off this project, put another layer of protection by tightening down the remaining two nuts. You may notice that the nuts are misaligned. Use the pliers to align them. Make sure you do this on both sides.
After this, you're done!
Step 10: Conclusion and Extensions
This is a really useful project, because not only does it protect your key, but it also allows you to get a good grip on it! When I ran, I used to drop my key all the time (so much that it got a little bent), but now I can hold onto it without worrying about it dropping and getting bent.
For modifying, you can use longer screws and put more keys on. You can also add a lanyard so you can put it around your neck.
I hope you enjoyed this brief project! If you have any suggestions or questions, feel free to comment!
  • Woodworking Contest
    Woodworking Contest
  • Spotless Contest
    Spotless Contest
  • Flowers Challenge
    Flowers Challenge
20 Comments
I like your idea very ingenious . It reminded me of when my brother and I were children and out playing with shorts that didn't have pockets. My mother used to get a bit of string and thread the house key though it so it was like a necklace. We would wear it around our necks under our clothes so not to catch on anything. We never lost our keys and could get in and out the house.
Your project has inspired me as it's very handy.
good for break something in the bank :p. btw. nice idea...
Thank you doodlecraft!
very cool , I made it is looking great ,thanks (:
Good instructable... however I'm not sure if this is the best solution to your problem.
It's working pretty nicely for me right now! Thanks for your comment!
This is great! Nice simple design and your tutorial is incredibly easy to follow along with :)
Thank you! I appreciate your kind words!
Heh - I have absolutely no use for this, but it does look pretty.
If I were to try build something like this, I'd be tempted to find a small spring-loaded switch blade, and replace the blade with a key. Just for the cool factor. :-D
Yeah that would be pretty cool!
Great instructable. Another solution I've used before is to put the last row of shoelaces through the end of the key and tuck it under. A key is small enough that I never felt it as I ran.
Wow, great idea! I'll keep that in mind! Thanks!
Of course! Anything with those dimensions with two holes at the end should do just fine!
