Simple Solar Day Lamp which lasts for 15 years by avd80
Featured
All buildings have areas which are in darkness during day time. In such locations we can use a solar day lamp. The lamp will turn ON when the sun rises and will turn OFF when the sun sets. There are no switches to be turned on or off. It will convert the previously dark area into perpetually bright area through out the day.
The total cost of this lamp will be about 700 Indian rupees.
Step 1: Material required for making solar day lamp
Material required:
You need following material (see figures)
1. Aluminum Channel
2. Wooden batten
3. Wood screws 0.5” long
4. Plastic or fiber washers 3 mm inner diameter
5. 5 White LEDs 1W rating
6. 3 Way terminal strip and mounting screw/nut.
7. Solar PV panel 12V 5 W
8. Wires
hshah2 says: Apr 23, 2013. 10:04 AM
Dear Friend,
where i can get solar panel in India - Ahmedabad ?
can you help me please...
satpathi says: May 17, 2013. 1:36 AM
Pl indicate suppliers of Solar panels in Bangalore .
avd80 (author) says: Apr 25, 2013. 9:31 PM
Hi,
You can contact Surana Ventures. They might send you to Ahmedabad by courier.
thanks
-Abhijeet
Marketing Executive
SURANA VENTURES LTD.
5th Floor, Surya Towers,
Sardar Patel Road,
Secunderabad-500003 (A.P.) India.
Contact No.+ 91-40- 27845119, 44665799
harika@surana.com
web: www.suranaventures.com
Fred_Sanford says: Nov 20, 2012. 1:24 PM
Pretty neat, 1 thing that i would recommend is to get a piece of plastic-wrap or film to put over the PV panel. Gives you rain protection and will keep dust from directly touching any circuit which could be fragile.
alexx22 says: Jul 27, 2012. 9:00 AM
nice instructables :D very usefull
avd80 (author) says: May 10, 2012. 10:47 AM
To enhance the utility of this day lamp following additions could be made to the basic circuit. It consists of two LED arrays, one PV panel and one two-way switch.
1. Make two units of LED array and install them at two locations where light is required.
2. Take a two-way switch. This has three terminals. Connect positive wire from PV panel to the middle terminal of two-way switch.
3. Connect the remaining two terminals of the two-way switch to the respective resistors of each of the LED array.
4. Connect the negative wire from the PV panel to the negative terminals of both LED arrays.
5. Now you can turn ON any one of the LED arrays by using the two-way switch.
Thanks,
Author
(Abhijeet Deshpande)
profpat says: Apr 10, 2012. 10:09 PM
nice one! i like it!
jessyratfink says: Apr 6, 2012. 10:57 AM
Awesome and very low cost. :D Great work!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
