The total cost of this lamp will be about 700 Indian rupees.
Remove these ads by
Signing UpStep 1: Material required for making solar day lamp
You need following material (see figures)
1. Aluminum Channel
2. Wooden batten
3. Wood screws 0.5” long
4. Plastic or fiber washers 3 mm inner diameter
5. 5 White LEDs 1W rating
6. 3 Way terminal strip and mounting screw/nut.
7. Solar PV panel 12V 5 W
8. Wires
Visit Our Store »
Go Pro Today »
where i can get solar panel in India - Ahmedabad ?
can you help me please...
You can contact Surana Ventures. They might send you to Ahmedabad by courier.
thanks
-Abhijeet
Marketing Executive
SURANA VENTURES LTD.
5th Floor, Surya Towers,
Sardar Patel Road,
Secunderabad-500003 (A.P.) India.
Contact No.+ 91-40- 27845119, 44665799
harika@surana.com
web: www.suranaventures.com
1. Make two units of LED array and install them at two locations where light is required.
2. Take a two-way switch. This has three terminals. Connect positive wire from PV panel to the middle terminal of two-way switch.
3. Connect the remaining two terminals of the two-way switch to the respective resistors of each of the LED array.
4. Connect the negative wire from the PV panel to the negative terminals of both LED arrays.
5. Now you can turn ON any one of the LED arrays by using the two-way switch.
Thanks,
Author
(Abhijeet Deshpande)
