Simple Solar Power Station/Air Compressor
7,227
21
4
Published
Introduction: Simple Solar Power Station/Air Compressor
This instructable is an entry in the Green Tech Contest, so please vote!
So I wanted a very simple solar power station that was simple to use and very easy to transport. So I started looking at jump-starter's. I found one made by cobra that had every thing I would need to have a nice power station that was very easy to transport.
Cobra sells a jump-starter/power-pack  that has jumper cables, charge indicator, usb, a light, a cigarette lighter outlet, a power inverter, and a air compressor. I found my power station at Cable's in the bargain cave for 25 bucks. It was discounted because it was missing the AC/DC charger.
I went to harbor freight and got a solar panel. It was only 15 dollars and came with its own built in charger controller and cigarette lighter plug.
So I got everything together and plugged the solar panel into my Power Pack. Once it was fully charged I put it to work.
I used it almost every day. It charges all my usb devices even my Iphone. I use the cigarette lighter outlet to charge my kids portable dvd player. I use the power inverter to run a set of speakers to listen to music. I can also run my soldering iron off of it. I have even used it when the power goes out to power my dsl modem so I can still have internet on my laptop. Its even useful at night as it has a build it flash light. And then to add to all the goodness it can air up my small 1 gallon air tank I use on my work bench for cleaning off dust. And then to top it all off. If I go to start my car and the battery is dead I can use this to jump start my car.
So If you don't have the means, knowledge or the time to build something like this here is the simple way to do it.
Anyway I put this together for the Green Tech Contest. The problem I was having was making a portable power-station that was not bulky and that the kids could carry around and not mess up. Well this did what I needed and then more. It also saves me a lot of power by not having to have wall-warts plugged in all the time. It also keeps me form having to run my big air compressor to fill up my little air bubble. So once again more power saved there.
So I know its not anything I made. But this is how I am helping use less energy.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    4 Comments
    How does the panel charge the unit? Did you have to splice a new connector to fit the charge port?
    Thanks,
    Daniel.
    The jumper pack that I used has a lighter plugin on it. So I just use solar panels with the same plug on them.
    How many watts is that solar panel? It looks like one of those 1 watt battery maintainers. Plus the price makes sense. The 1 watt panels are good for battery maintaining, but they can't charge it much.
    Good luck in the green tech contest! If you want to have a look at mine my link is below.
    https://www.instructables.com/id/Home-built-solar-power-system/
    Yes the solar panel pictured is a small panel used as a reference. I do use a few larger 5 watt panels to charge it.
