Simple Sonic Cat Repeller
26,930
114
20
Published
Introduction: Simple Sonic Cat Repeller
About: Young, inexperienced and dangerously close to being funny. Polite corrections welcomed.
Cats, teenagers, kids: at least one of them likes to use my garden as a toilet, but fortunately they can all be repelled with some simple electronics. I’m going to use a 555 astable to produce a high frequency square(ish) wave signal that should range from annoying to painful for the “targets”, whilst remaining inaudible for most adult humans. I’ll try to make my instructable easy enough for relative beginners to understand.
Step 1: The Plan
This is how I’ll make the repeller.
The frequency of the output of the chip in this setup is given by the formula
Frequency = 1.44/((R1 + 2R2)C)
From experience I know that 12,000 Hz is a good frequency for the job, but feel free to try out others with different values of R1, R2 and C (if you have a breadboard I recommend trying a 100kR variable resistor as R1 and finding a suitable frequency). Do bear in mind that R1 should be at least 1kR.
12,000 = 1.44/((R1 + 2R2)C)
1.44/12,000 = (R1+2R2)C
1.44/(12,000 x 0.0000001) = R1 + 2R2 = 1200
I’ve used 100nF as my value for the capacitor, and I’ll use a 1kR resistor R1 and a 100R for R2.
As I’ll be using a 9V PP3 battery for +Vs, and my red LED has a voltage drop of 2V and draws 30mA of current, I ideally need R3 to be 233.3R. I have 220R resistors, but as they have 1% tolerance (i.e. they go up to 222.2R) they aren’t suitable to protect the LED from excessive current. The next highest value of resistor in my supply is 270R, which would limit the LED to drawing 25.9mA – perfectly acceptable. Check the ratings for your LED – don’t complain to me if its ratings are different to mine’s and it blows!
Ohm’s law: Current = Voltage/Resistance
Therefore Resistance = Voltage/Current
(9-2)V/(30 x 10-3)A = 233.3R
R4 is to increase the impedance (read resistance) of the output into the speaker. As with the LED’s resistor, less resistance means more current, and as power (in Watts) is given by current x voltage, less resistance means more power. “Nice!” I hear you remark in your best Jeremy Clarkson voice, but not so when you try to pass 2W into a speaker designed to take a maximum of 0.25W and you’re left with an expensive magnet. Read the specs for your speaker – do the maths and aim for the nominal power and don’t go over the maximum power. The nominal power of my speaker is 1W with a maximum power of 1.5W. A 47R resistor for R4 in series with my 8R speaker will give 1.02W of power (having measured the output of the 555 as 7.5V with a 9V supply).
Step 2: Parts and Tools
Parts list:
555 integrated circuit (IC) chip
10nF capacitor
C (100nF)
R1 (1000R)
R2 (100R)
R3 (270R)
LED
SPST (single pole single throw) push to make switch
Miniature speaker (check that your chosen frequency is within its specified frequency range)
R4 (47R)
Stripboard or a PCB if you’re rich
8 pin socket for the IC
PP3 battery clip
LED panel clip (the appropriate size for your LED)
Wire (single core or stranded - not much)
Suitable container (bearing in mind what you’ll have to fit in it – for me it will be the battery, stripboard and switch, with the speaker mounted outside to allow a narrower box)
Tools list:
Wire cutters and strippers
Screwdriver
Pliers
Soldering iron and solder
Drill
Tool to break stripboard tracks (try a small drill bit)
Electrical insulation tape
Masking tape
Adhesive pads or glue
Pen (e.g. a Sharpie)
Continuity tester (your multimeter may include one)
Step 3: Construction
Start by breaking your stripboard down to size. We need 8 copper tracks, each ten holes long. Count these off carefully and mark the break points with your pen. We’ll be breaking the stripboard through the middle of the next line of holes. Line up the bit that you want over the edge of something sturdy with a sheer edge, like a tool bench or a window ledge. Hold the board down tightly with the palm of one hand (or secure it with a vice if you prefer), and push down the other end firmly over the edge with the palm of your other hand. *SNAP!* Retrieve the piece from the floor and repeat the procedure on it if necessary. Any jagged edges should be pulled off with pliers.
Break the stripboard at the points marked by red Xs on the diagram. I put a 3mm drill bit in the appropriate holes and manually twisted it until the track was completely broken in two (using a continuity tester to tell). Then insert and solder your resistors, capacitors, IC socket (NOT WITH THE CHIP IN IT), wires with both ends in the board, 0v (black) lead of your battery clip and wire to the switch (10cm)  a few at a time, working from those with the lowest profile (resistors) to the highest (capacitors). A little masking tape is a good idea to hold everything in place whilst soldering. Solder the switch to its wire from the board and the +Vs (red) lead of the battery clip (a terminal each). Solder by heating the copper tracks with the iron for a few seconds, and then apply a little solder to the components.
For both the LED and speaker wires, cut and strip two wires of good, equal length. Grip one end of each wire in your pliers, and twist the two wires together all the way along their length, with about a centimetre left at each end. One end of the speaker wires can now be soldered into the board- untwist them a little if they won’t reach the holes.
To solder the LED to its wires, twist its legs around them as much as you can (long leg to red; short leg to black). Put something across the legs to absorb the heat and protect the LED, such as a crocodile clip or a paperclip. Try to run a decent amount of solder along the length of where the legs meet the wires. After it’s cooled, cover up the bare metal with insulation tape. Then solder the other ends of the wire into the board.
Read the specs for the switch and LED clip to find the size of hole that you need to drill in your box. If you plan to mount the speaker outside of the box like me, you should also drill a 3mm hole for the twisted wires to pass through.
Knut your switch and clip your LED into their holes. In order to make the circuit removable from the box, I made another short twisted wire pair which I soldered to the speaker connections (using my continuity tester and pen to mark polarity). Then I connected these to the original leads inside the box using two screw connectors. If you don’t fancy this you can thread the leads through the hole from the inside and solder them to the speaker, which I am mounting on the outside of the box with a couple of adhesive pads.
Step 4: And We're Done!
Stick it in the box. Screw the lid on. Give it a go.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    20 Comments
    It would be a good device for revenge on an inconsiderate dog owner if you installed a latching switch,assuming it can operate at the right frequency.
    I want to produce 23000 Hz frequency and i have calculated my resisters and capacitor as R1(2000) R2(2130) and C(0.01 micro Farad) . how can i measure my out put voltage and current to give nominal power to the speaker.. and what power of speaker should i use for producing such frequency ?
    how can i increase the amplitude of the frequency?
    Is there any video of this working?
    I've tried some products with my cats and they just ignored it! :(
    I'm thinking on bying a arduino just to try this.
    Great Instructable. I'm building one of these to keep the local cats from using the gravel in our garden as a latrine.
    Can you give more detail in calculating the value for the resistor on the speaker?
    I've got a 6v power supply and a 3 watt speaker.
    Can you give the actual formula you used to calculate your 47r resistor?
    Actually, I think I've solved it.
    Something like....
    voltage / desired watts = current
    5v / 2.5w = 0.5A
    (voltage and watts are approximate - will check when at home)
    Then R=V / I
    5v / 0.5A = 10R
    Hi Beenay, thanks. As Watts are Voltage x Amps, Watts / Voltage or Amps will give the other. (E.g. 2.5W/5V = 0.5A).
    5V/0.5A = 10R, so you would need to make the load impedance 10R by adding resistors in series or in parallel with your speaker (after checking the impedance of the speaker).
    However, a 555 timer can't supply more than 0.2A of current. To get a 2.5W output, I suggest adding an audio power integrated circuit between the 555 and the speaker. You may need to use a larger power supply Voltage (whilst remaining within the range of the 555's supply) and reduce the output Voltage of the 555 with a voltage divider.
    Thanks for reading my Instructable.
    Might even be useful for mosquitoes as well.
    How effective is it against teenagers? Why don't adults get affected by this? Will it work against other annoying things, like politicians?
    Politicians....lol. Love it!
    The approximate human hearing range is 20-20,000Hz, but this is seriously affected by age and exposure to loud noises- from machinery to excessive use of headphones at high volumes. Basically (and depressingly) your hearing will be deteriorating for most of your life. Most teenagers will be able to hear 12,000Hz (quite an annoying frequency when heard for a while), but most adults won't. If you can- congratulations! As for politicians, given what I've said about age, I'd go for a wet sponge...
    What if you don't have a sonic cat, just a regular one?
    throw'em some water
    Ok, admittedly its effect is limited on deaf cats... ;)
    Does this frequency can disturb my dog? great device btw!
    Thanks! Dogs and cats have much greater hearing ranges than humans (dogs about twice as wide; cats about thrice as wide), so if your dog's hearing is healthy then it should be able to hear the device at 12,000Hz. Whether it'll disturb a dog... Try it and let me know. :)
    This is definitely a great use of 555 timers. Keep up the great work!
    Thanks for the encouragement! :)
