Simple Stereo Amplifier
106,799
119
82
Posted
Introduction: Simple Stereo Amplifier
Though it may not look like it, the circuit in this instructable is so easy anyone with even incredibly basic electronic skills can do this.  The circuit shown below is actually 2 mono amplifiers (mono is single channel, for those who don't know).  You don't even need to know how to solder and almost all the parts can be purchased at the nearest Radioshack.
P.S.  The camera that I am using is old and close-up pictures are blurry.  Also the microphone on the camera sucks so the circuit will appear to be horrible-sounding, but it actually sounds good when you play it in your room or wherever.
Step 1: Gather Parts
What you'll need:
2-  LM386 audio amplifier IC
2-  220uf of greater capacitors
2-  0.1uf polyester capacitors
6-  jumper wires
1-  1/8" stereo headset jack
2-  speakers
1-  9 to15 volt battery
1-  connector for battery
1-  breadboard
Step 2: The Diagram and Pre-Build Info
This is the schematics for one of the channels.  Build two of these.  On your jack you will need to know which are your signal wires and which are your grounds.  On the next step I will try to show you where to make your connections (how to breadboard the circuit).
Step 3: Build!
Assemble.  Use the pictures as i put the notes on them:
1) Put the chips in.
2) Put in the polyester caps as shown.
3) Plug in the jumpers from pin 2 to pin 4 on each chip.
4) Attach jumpers from pin 6 to the positive side of your power supply.
5) Attach the 220uf caps as shown.
6) Connect the headset jack connections.
7) Top view of previous picture.
8) Hook up a jumper from pin 4 to the negative side of your power supply on each chip.
9)Add your battery connector observing polarity.
10) Connect your speakers.
11) Add battery and double check connections
12) Yay! You're done.
Step 4: Have Fun
Here is a video of the circuit in action.  Like i said in the beginning of this instrctables, the mic on my camera sucks so the sound quality of the video will be horrible as well, but in real life the sound quality of this circuit is pretty good.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    79 Comments
    This is sooo simple to build and it sounds good
    i've built half of it (only had one IC) but when i use it the IC heats up. Where should I add the resistors? Thanks for thegreat instructable
    For people asking about volume control, I added a 10k pot from pin 8 to a 10µf cap to pin 1. With the pot I have one in the middle and one on the outside. It seems the range is small after I go pass the mid point of the pot, could be the pot or whatever but that's what worked for me.
    7 is left alone, if you put a 10µf cap between 8 and 1, + on the 1 pin side, it will boost gain.
    i don't understand why in the diagram there is only 1 input shown ?? what about the other
    and the value of ceramic is .01uf
    how about if ceramic capacitor I use
    is it Okey
    can i power it buy laptop usb connection
    how will we supply volt to both ic's????should we join both the ground and positive wire with each other from both the ic's and then supply it with 12v???????????
