Simple Street Lamp With Paper
1,887
33
Posted in TechnologyLeds
Introduction: Simple Street Lamp With Paper
Simple street lamp with page & some electronic components
I used for night lamp, also can use decorate your home or anywhere you want
Power by 5v usb cable
Detail all steps, you can watch video
Step 1: The Road
You need A4 paper high thickness with black paint for make ground
(paper high thickness use only for make ground)
Road Lines, make paper pieces with size
1.5 x 3cm (x5)
0.7 x 2cm (x3)
apply to ground by double sided tape or glue
Materials :
- A4 paper high thickness
- A4 paper normal
- Black paint & Paintbrush
- Double sided tape
- Paper Glue
Step 2: Street Light
This step for make street light, with frame is paper and light by led 1w
single core copper wire is important for stable frame
Materials :
- Led chip 1W
- single core copper wire (copper diameter 0.6mm)
- 33 ohm Resistor
- Heatshrink Tube
resistor for limit current and heat of led, also change brightness
1 ohm is best for max brightness
Step 3: Traffic Light
Next for make traffic light, i use led 3mm (red, green, yellow)
frame still by paper
Materials :
- Led 3mm (red, green, yellow)
- normal copper wire
- 10k Resistor (x2)
- 20k Resistor
- Heatshrink Tube
- Prototype board
Step 4: Assembly
Put street light & traffic light at position you want, make holes on road for wire can through
And use tape, glue make stable position for light and wire
Then solder for group wire (+ -) of street light & traffic light
USB cable cut wire green and white, use only red (+) and black (-)
Solder again for group all wire, don't forget add other A4 paper for cover and protect wire
Step 5: Complete & Test
Power with 5V from adapter or USB port of desktop, laptop, powerbank
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    2 Comments
    this should be an easy way to buildt street- and traffic-lights for a railway-modell. (HO ; 1:87) When using a micro-controller vor the traffic-lights, it will be perfect ! Greetings from Germany
