Simple Super-Macro/Microscope Webcam Conversion
 by Zephyris
Featured
Step 1: The raw materials
You only need two things for this microscope:
1. A webcam with an unscrewable lens (I got a really cheap one for about £5 on ebay)
2. Blu-tac
It is absolutely vital the webcam has an unscrewable lens, almost all do (and for most webcams this is actually the way you focus!).
Step 2: Dissasembling the webcam
This bit is dead easy, just unscrew the lens from the webcam! Once you have taken the lens out be careful not to get any dust on the CCD (the sensor in the body of the webcam) or on the back of the lens. Dust on either of these is very hard to clean off and can mess up the pictures.
Step 3: Reassembling the webcam
Now just use blu-tack to stick the lens back in the webcam, but backwards. Make sure you get a nice tidy fit, you want to avoid any light leaking around the edge of the lens. For me this was simple because the lens slotted neatly back into the body of the webcam. For some webcams you will have to use a thin sausage of blu-tac to seal around the edge of the reattached lens.
Step 4: Using the super-macro/microscope webcam
It is really simple to use, just point it at a (well lit) small object! To focus the image just move the webcam towards or away from the object, the lens will probably need to be a few millimetres away from the object. It is a bit fiddly to keep the webcam in position once it is in focus, I used blu-tack on the stand to help hold it still.
If you want to "zoom in" (increase the magnification) you have to move the lens further away from the sensor. The simplist way to do this is with a tube of paper or card stuck into the webcam body which you can put the lens in. Again, be careful with light leaks - black card or paper covered in tin-foil will be very good at blocking stray light.
Step 5: Measuring performance
To calculate the magnification of your new microscope you need to take a picture of something you know the exact size of. The easiest and most common small object to do this with is a pixel on a computer screen.
Take a picture of the pixels of your screen, then open the captured image in some photo-editing software. Measure how wide the image of one pixel is (in pixels), this is the magnification factor.
You can also calculate how big the field of view of the webcam image is from the ppi of your screen:
(25.4 / dpi) * n = fov
ppi is the "pixels per inch" of your screen, commonly 72.
n is the number of pixels that fit across the captured image.
fov is the field of view, measured in millimetres.
I have attached an example image from my modified webcam. Here the image of a single pixel is 130px across so the magnification factor is 130x. It is a picture of a 72ppi screen and 5 pixels fit across the image so the field of view is about 1.75mm!
mikkelbg says: Aug 31, 2010. 2:56 PM
What webcam did you use?
Zephyris (author) in reply to mikkelbgNov 14, 2010. 2:45 PM
See my reply to shadowdude77 above...
shadowdude77 says: Nov 12, 2010. 2:56 PM
I'd also like to know what model webcam you used if you know what it is. It turned out very nice the way you did it and if I have to spend an extra few dollars to ensure that the mod will be easy and effective, so be it.
Zephyris (author) in reply to shadowdude77Nov 14, 2010. 2:45 PM
It is an Advent ADE-13MP+, it's a very old model so you may need some luck finding it!
legomaster2000 says: Aug 21, 2010. 1:34 PM
Awesome instructable!!! I am making one called "how to make a PowerPoint sprite battle" Don`t get mad at me about it just because it has no photos
diolola says: May 14, 2010. 2:19 AM
Hi, Zephyris and NostalgicStone,
Thank you for the advice.
The model of my old PC Webcam just says -MODEL-X-EYE, and it is screwable type with  reddish lens outside.
My OS is windows 7.
Looking forward for the next reply, or else I will do something else, I'll keep this old stuff.
diolola
diolola says: May 13, 2010. 10:29 PM
Hi Zephyris,
I have a 4 year old webcam and wanted to use it to experiment by your 'tibles. How can we connect this to the laptop I have through USB, does this requires a driver or not. I have no idea of these things, so please bear with my innocence.
Thanks a lot.
diolola
Zephyris (author) in reply to diololaMay 14, 2010. 12:39 AM
As NostalgicStone says you almost certainly will need a driver which will depend on the webcam model...
As for software I would recommend "YawCam", it is free with a lot of useful features.
NostalgicStone in reply to diololaMay 13, 2010. 11:43 PM
 Chances are buddy, you will need some sort of driver installed to get the webcam to work on your computer.
You will also need some webcam software to view the image too.
What is the model number on the camera, and what is your operating system?
With that information we will most definitely be able to help you out!
jimofoz says: May 13, 2010. 8:03 PM
I'm definitely going to try this out. However, one nit to pick, is that actually it's a removable or maybe "screwable" lens. If it was truly unscrewable, you wouldn't be able to unscrew it.
At first I was wondering why you didn't want a removable lens when you needed to take it out.... But don't mind me, I'm only bright enough to criticize, not create.
eight says: May 13, 2010. 6:34 PM
Well done instructable. Ta for your efforts...
Say... wasnt "Zephyris" the guy from Babylon 5 ?
Mig Welder says: May 13, 2010. 12:28 PM
nice 'ible! I'm definitely going to try this.
Did you take those pictures in the previous steps?! Those have to be some of the best DIY pics I've seen. Most I've seen are crooked, out of focus, and with really weird lighting!
Zephyris (author) in reply to Mig WelderMay 13, 2010. 1:59 PM
Of course I took those pics! I am quite anal when it comes to presenting things well :)  I should make an instructable on it!
arrow_strider says: May 13, 2010. 8:38 AM
Very nice instructable!
I´ll definitelly do it with some old webcan i have here.
MoritzB says: May 11, 2010. 6:35 AM
Here´s a video of my diy microscope webcam
http://www.youtube.com/watch?v=O2rtb8GJdy8
Zephyris (author) in reply to MoritzBMay 11, 2010. 8:07 AM
Looks good, about the same magnification as I got (except my mod was reversible! :) )
kelseymh says: May 9, 2010. 11:01 PM
Congratulations on getting featured in the MAKE blog!  I missed this project the first time around -- now rated and featured.
Zephyris (author) in reply to kelseymhMay 10, 2010. 12:43 AM
Ooh, mentioned on MAKE blog! Excellent! :)
McGrep says: Mar 4, 2010. 6:37 PM
Very cool 'ible. I love the simplicity and ease of doing this to a webcam. Also, depending on the lens, this is extremely reversible in case something goes awry or one still wants to use it regularly. Great!
michaelgohjs says: Feb 27, 2010. 7:47 AM
OH YA!! i just tested it out...
had to cut the lens mount a little here and there
but it really is cool
think i gona do some upgrades and post an instructable
eyerobot says: Jan 27, 2010. 8:29 AM
Very cool idea.
This would come in handy while working on miniature objects.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
