Introduction: Simple Tea Bag Extractor
Once a day I drink a large mug of Tea.
Unfortunately there are times when I forget to take out the tea bag and I end up with a very bad tasting tea.
There are 2 types of tea I consume, peppermint and a green tea.
I can handle a strong peppermint tea, but not over-steeped green tea.
I could set an alarm or wait in the kitchen for the tea to steep, but that's not a perfect solution.
In this Instructable, we'll make a simple Tea Bag extractor.
No more over-steeped tea!
What's needed:
- A Ping-Pong Ball
- Plaster of Paris
- Popsicle Sticks
- Kitchen's Timer (Similar to the one I used)
- Some kind of Base to attach the gadget. I used a wooden plate
- "L" bracket
- Nylon nuts and bolts (optional)
- A washer (optional)
- BBQ stick
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1:
I cut a hole in a Ping-Pong ball.
After heating a part of the ball with a lighter, I used a pen to make a little dent.
Step 2:
I mixed Plaster of Paris and poured it into the ball.
Then I put a popsicle stick in the center and let the plaster set.
Step 3:
To make the ball look more appealing, I glue a purple washer to it.
Step 4:
I prepared popsicle sticks by drilling holes, cutting them shorter etc.
We ended up with 6 popsicle sticks
Step 5:
The gadget was assembled on top of an "L" bracket that was attached to a wooden plate.
I used nylon nuts & bolts, because they don't loosen as easy as metal ones.
Step 6:
I cut off the tip from a BBQ stick and glued it to the popsicle stick.
When the glue was dry, I cut off the excess.
Step 7:
I opened an egg shaped kitchen timer and attached the base to the bracket.
Step 8:
I put back the top piece to check where I need to drill a hole.
When that was done, I put a bolt into the hole.
Step 9:
After making sure the gadget is calibrated, I screwed another screw into the bottom and glued both pieces of the timer together.
Step 10:
I made a little cut in the popsicle stick, so it can hold the tea bag better.
Step 11:
That's it!
You can steep the tea up to 1h.
When the timer reaches "0" minutes, the arm will lift the tea bag.
