iImage Information
A while ago I built a telegraph machine and was amazed by the simplicity and the joy obtained from pounding out my name hundreds of times. When I saw that the weekly challenge was magnet themed, I knew that I had to make an instructable. I was able to build it in an hour while taking pictures, and I bet it could be done in about 30 minutes. Telegraphs are simple communication devices using a switch operated at one station to control a electromagnet at a separate telegraph station. The electromagnet then will pull down a piece of steel for a short time or a longer time (dot or dash). It was used in the U.S. civil war and as used as a major communication device from the early 1800's until the mid 1900's. Now let's go make one!
Step 1Materials
iImage Information
These Items can be found in any workshop or hardware store and are pretty basic:
Scrap wood (Plywood and a board about 3 inches high)
A nail a little taller than your board of wood
Some sheet steel (thin)
Copper sheet
Bottle cap
Insulated or magnet wire
9v battery and holder
assorted nails and screws
Tools:
Hammer
Screwdriver
Drill
Saw (If you need to cut the wood)
But then you have to Found it's Frequency... Its a hard work.
