3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple USB Altoids AA Charger!
Step 4Your done!
Your done!
After you charged your batteries up put them in and you made your own AA charger that outputs around 5 volts!
7 comments
Apr 23, 2010. 7:57 PM8888tx says:
I've got a slight problem. The as soon as I touch the wires to the batteries it turns whatever im using off,
Jan 8, 2010. 10:43 PMAndy-K says:
 Would this work better if you put a 4.8v regulator in it. Between the USB cable and the battery holder. Since my 4 NiMH Batteries are equaling 4.8 volts (4*1.2v) I think this would be safer. Im not sure if Im correct though, Im kind of new to electronics.
Aug 17, 2009. 2:25 PMBrad79 says:
Send power down the data ports the middle ones on the usb . But with these batterys i cant see it charging it for long . The batterys will drain.
Jul 30, 2009. 5:25 PMWiggin says:
Is this safe for expensive cell phone equipment? I looks really cool and easy. Almost too cool and easy to be safe ;-)
Jul 30, 2009. 6:45 PMPadlock says:
It isn't regulated; with alkaline or lithium ultra batteries it would be 6 volts or lower, with NiMh it would be around 4.8. Defiantly not! I would only use this for simple, hard to break stuff. (Say a keyboard light, or fan.)
Jul 30, 2009. 10:42 PMPadlock says:
NiMh batteries have a nominal voltage of 1.2 volts. 1.2 times 4 = 4.8. But, as NiMh batteries are used, their voltage decreases. That means it's all a guessing game... low voltage can mess up IC's, voltage transducers, and the like. So, it is NOT safe. If this had a step-up and regulator, it would be much, much more safe. The only thing I would trust with this is non-voltage dependent objects (like a keyboard light or fan) and defiantly NOT expensive cell phone equipment.
Jul 31, 2009. 8:26 PMPadlock says:
I'm guessing that you have the "Ultra" type batteries, which have been specifically engineered to provide power more congruent to that of a AA. I'm just here to point out that it isn't safe for everything, and in fact could be quite destructive on some technologies.
Aug 1, 2009. 8:58 PMsuperken67 says:
I have built a usb charger based on these instructions. I have tried it with both 4 AA and 4 AAAA batteries, but the outcome has been the same. When I connect it to my iPod or Zune, nothing happens. However, when I connect it to a flash drive, the light turns on, so the circuit works but something else is wrong. Do you have any ideas on what I can do? (P.S. it is set up in a series circuit, not parallel). Thanks.
Jan 24, 2012. 4:15 PMaxeman911 says:
What you want to do is connect the middle to pins of the Female usb together, this tricks the ipod into thinking that it is a legite apple charger.
Mar 29, 2010. 7:42 AMUnclefisty says:
I've connected both a Zune and iPod to non OEM chargers and they worked, I have a generic 12v car socket usb charger that works with both.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:dabomb1022
