Simple USB Charger
Published
Introduction: Simple USB Charger
note: you can't depends this charger Except in emergency cases because it may affect on the life span of the battery
Step 1: Component That You Need
1- 9v battary
2- battary Socket
3- 100nf capacitor (2)
4- 100mf capacitor
5- 74mf capacitor
6- resistor 470ohm
7- led
8- USB socket
9- regulator lm7805
10- switch
Step 2: The Circuit
you can build your circuit online at this site
www.circuitlab.com
Step 3: The Final Result
After connecting the circuit it will be like that and it will be ready to charge your mobile
Step 4: My Mobile Connected to the Charger
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    9 Comments
    how many hours does this circuit take to charge :)
    Most smart phone batteries are 1500-3300mah.
    A 9V battery has 50-400mah and at 500mw load has less than 300mah capacity.
    You're also losing 30% of that 300mah thru the 7805 as heat.
    Just exactly HOW much does this remaining 210mah charge your phone ???
    Ref : http://www.powerstream.com/9V-Alkaline-tests.htm
    9v battery gives about 400 to 500 mA per hour
    to Slow the charging process as much as possible
