Simple USB Switch by T_T_
This is the most simple USB  switch I could come up with. It doesn't require IC's or any other complex circuitry.
All it requires is:
One 4pdt switch
Two USB female ports
one USB cable
and a case
Atariiatarii says: Feb 21, 2013. 6:16 AM
Would this work in reverse? like, one female port and two male ports? I want to be able to switch mouse and keyboard between computers without using synergy
sctirvn687 says: Jun 25, 2012. 12:00 AM
Does this switch turn the two USB ports on and off or does it just switch between them? Would you use this instead of plugging in and unplugging cables? Thanks.
T_T_ (author) says: Jun 25, 2012. 1:07 PM
this just switches between the two ports.
right now I don't use it, as I've upgraded my computer and have no shortage of ports, but it is much easier than unplugging the cables, especially if the ports are on the back.
T_T_ (author) says: Jun 25, 2012. 1:08 PM
oh, and this particular switch can also turn off both ports
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
