Remove these ads by
Signing UpStep 1: Construction
-Cable with male USB end
-12v computer fan
-Solder
-Electrical tape
Assembly
Strip the ends of the USB cord to revel 4 wires. Strip only the ends of the blue and green wires. Strip the ends black and red wires on the fan too. Solder the Green wire to the black one and the green to the red. Wrap electrical tape around the connections. Now wrap electrical tape all around the exposed wires. Plug it in to your computer's USB and Place on a vent on the router. This simple fan will keep it from over heating during long uses and will prolong its life.
Visit Our Store »
Go Pro Today »
http://www.poweroverethernet.com/articles.php?article_id=52
"An obvious requirement of the spec is to prevent damage to existing Ethernet equipment. A "discovery process", run from the Power Sourcing Equipment (PSE), examines the Ethernet cables, looking for devices that comply with the specification. It does this by applying a small current-limited voltage to the cable and checks for the presence of a 25k ohm resistor in the remote device. Only if the resistor is present is the full 48V is applied, but this is still current-limited to prevent damage to cables and equipment in fault conditions."
I guess if the above quote is correct, a 25k ohm resistor, a 12 volt voltage regulator, and a pair of filtering capacitors could be used to power the fan...
According to that article you can use pins 4 and 5 as positive and 7 and 8 as negative but I wonder that how the 25k was planned to be installed, parallel to the load?
And yeah, you still have to check that your modem supports this. Otherwise things can get ugly :P
