3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple UV lightbox for PCBs
Step 8Install the tube bases and mirror
The next step is to decide where you want to put your UV tubes. Place your mirrored card/plastic/tin-foil down first and clip the tube holders onto the tubes about 10mm in from each end.
Cut up eight pieces of choc-strip connector and screw them onto the tube pins (unless your posh and have tube connection clips!) this makes wiring to the tubes easy.
Place the tubes down on the mirror and shuffle them around until they are in line and leave enough room at either en of the choc-strip to fasten the wires in.
With a small marker pen, mark where your tube clips are and then drill and bolt the tube holders down into position.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Tvmender
Hi, I am Sam and live in East Yorkshire, England. I am an electronics Engineer and enjoy everything to do with electronics. I enjoy programming and systems design as well as High Voltage stuff such ...
more »
