3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Variable Neutral Density Filter
Step 4Final Assembly
Final Assembly
Screw the two polarising lenses together making sure the normal filter is on the camera side and the flipped lens is on the other side.
If you don't plan on using the unmodified filter as a polarising filter on it's own then you can glue the two together to make sure you don't get confused. If you do want to glue the filters together be careful; to use the filter you have to be able to twist the front filter while the back filter remains stationary - don't jam the twisting mechanism with glue! Also avoid using cyanoacrylate-based glues (eg. superglue and krazy glue), their vapours can fog the glass.
1 comment
Jun 18, 2010. 2:25 AMyamahito says:
Nice. You can also get away without modifying the front polariser if you can get your hands on a linear rather than circular polariser. However these are quite rare these days as they would normally interfere with TTL measurements.
Jun 24, 2010. 1:04 PMA.Mac says:
Considering the Singh-Ray variable ND filter runs between $350-$400, I think £25 still counts as pretty low-cost. Regardless, thanks for the 'ible
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Zephyris(RichardWheeler.net)
I am a not-very-closet geek, when I am not doing science (my job) I tend to follow my other geeky passions; making, drawing and creating things. These are some of my vast collection sites I contribut...
more »
