3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Wallpaper Using Photography and Layer Blending - Photoshop Tutorial
Make a Visually stunning Wallpaper using a simple technique inside photoshop.
Anyone can make a wallpaper this good, and its alot easier than you might think!
So, first things first go to-
  • File > New
Set your width and height to pixels, and set to the same size as your screen, Your resolution will be fine at 72 pixels/cm
Set the colour mode to 'RGB', and the Back ground to 'Transparent'
  • Click ok
Step 1Adjust it!
Adjust it!
Now we need to get our chosen photo into the new document.
  • Open up the photo in photoshop
  • Select the Move tool
  • Drag the picture across into the new document window
You should see the picture sat there - Depending on your camera, you will most likely find that the picture is way too big.
Zoom out by pressing Command -
(CTRL - in windows)
Select
  • Edit > Free Transform
Using the Handles adjust the image till it just fits the document.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
