I will Teach you how to make a simple water sensor circuit
Step 1: Gather Parts
Parts List
1 General Purpose NPN Transistor $0.10
1 50K Trimpot $0.15
1 47ohm Resistor $0.01
1 LED $0.08
1 Proto Board or You can etch A PCB
1 3 volt power source battery, wall wart, whatever
paxipatel says: Jun 16, 2012. 2:32 AM
how it works
mr_man says: Jun 13, 2012. 5:46 AM
I like that you put the 22k resistor in "Step 6", and this can be used in the circuit in "step 2" as well. It reduces the probe current, and protects the transistor in the event that the probe electrodes touch each other and short, and reduces the chance of electrolysis generating gas bubbles on the probe electrodes. Also to reduce electrolysis, you could just use 1.5 volts across the probes
Also with a 12 volt supply, you'll want use a higher value resistor than 330 ohms on the LED.
The circuit will probably work without the potentiometer.
sala89 says: Apr 4, 2012. 4:47 AM
how much cost of this project in india
manjotmessi says: Nov 5, 2011. 10:28 PM
please give me a detailed process of fuctioning of a transisitor in a water level indicator project.
mboruah says: Oct 7, 2011. 9:54 AM
is any other option not available,i m really not getting it.........
sahilaggarwal says: Jan 21, 2011. 9:23 AM
here transistor is used for amplification ??????
and why only BC547 OR 548 is used???
Cyberscann54 (author) says: Sep 4, 2011. 5:07 PM
I know I have bad hand writing but it also says any NPN transistor will work
jpsailr says: Sep 26, 2009. 6:35 PM
After many attempts to make a circuit like this, I gave up. Reason: when current flows through water from one plate to another, gas builds up on the sensor plates and the conductivity of the water reduces until it is undetectable, over 10 megohms within minutes. So if you're not there right when it happens, you will miss it. I solved this by creating a circuit which would put an AC current on the sensor plates. This continually purges the plates of gas and keeps the resistance through the water to less than 100 Kohms - very useable. This test ran for over 4 hours with no loss of conductivity. Now I successfully use it to detect bilge water as soon as it happens, or water on the basement floor. I will submit a project when I get it written up.
MarleneL says: Feb 24, 2011. 2:40 AM
I am working on a hybrid hot water system and need something like what you are describing... can you please forward me some more information on it please!! Thank you.
eng_tako says: Oct 19, 2010. 9:08 PM
thank you very much you help me alot
wonderingoutloud says: Sep 9, 2010. 8:38 AM
Assuming clean water, zero turbulence, very small inflow related to volume, could I get 1/32 inch level gage accuracy? In other words, under perfect conditions, what accuracy could one expect?
Cyberscann54 (author) says: Oct 15, 2010. 9:26 PM
it is a circuit designed to give you a visual alert that you need to fill you water tank in a vehicle accuracy is not part of its implementation being cheep and simple is. If you wish to have a sensor circuit that is that accurate this is not the way to go. Why do you need such accuracy what are you trying to build ???
palabuto says: Aug 29, 2010. 5:10 AM
do you have the c-language for this project
Zhelnot says: Aug 5, 2010. 10:40 PM
are you done with this thing??
geniusgippy says: Jun 8, 2010. 9:59 AM
can nybody eloborate on which HHO cell to use!!!
Cyberscann54 (author) says: Jul 13, 2010. 4:05 PM
I would recommend a dry cell the circuit would be placed on the water fill tank
mathew086 says: Jul 10, 2009. 2:01 AM
Hey... I find this one soo interesting n simple that i am planning to try oit put once. but i have a small question? How much current does the circuit consume for one time function. meaning if the circuit detects water how much currents is consumed by the circuit from the 12 V battery??? thanksss
jonoxer says: Aug 6, 2009. 12:02 AM
That's pretty easy to figure out with Ohm's Law. There are two paths that current will take through the circuit: the first is through the LED and into the collector of the transistor, and the second is through the probes, the water itself, and the 22K resistor. The current through the LED part of the circuit will be about 36mA, and assuming the water has perfect conductivity (it definitely doesn't, but that's a worst-case scenario) the current through the probes will be under 1mA. In other words, trivial.
stephenniall says: May 10, 2009. 2:53 PM
oo very cool and underated
DarkAngel09 says: Nov 24, 2008. 6:27 AM
Seems like a really cool project I may have to try it out. We have a sensor project in school to do I may use this project for it. Ill send you the results if you are interested.
the man gadget says: Aug 11, 2008. 2:07 PM
PS electrolyte is a good move too...baking soda is a good start.....
the man gadget says: Aug 11, 2008. 2:05 PM
I have built some equivalents to this and the results are OK but not great...look up the dry cell version..it is more complicated but the results far better for me so far at 1Ltr/Min @12v/5A
vancecook7 says: Jul 29, 2008. 7:59 AM
If anyone has built and tested this in an actual cell, please let post the results here. I am curious if foam may conduct enough to keep the LED from lighting when the water level drops but cell is still in operation. If the cell is in a vehicle, do corners trigger the circuit?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
